how to get surround sound with seat against wall?
poloman1211
well i am trying to set up a 5.1 system but the room i have my set up in, the sofa is against the wall and there is no room for any speakers, so how do i set up speakers to have surround sound or do i have no options. i do not what to put speakers into the wall. any info would be great
thanks
thanks
Post edited by poloman1211 on
My setup is the same way, i mounted my R150's at ear level turned in slightly, sounds nice to me!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
I have a similar setup but even harder with windows along the side and rear walls, so I had to opt for ceiling mounting my rears, but was able to point them down towards my couch:
http://erikt.cts.com/Pictures/hometheater/RTI4-Omni-mount-2.JPG
The rears do not point directly at the couch and listening spot but over so that it is harder for 'localization' of the rear source.
Ya gotta do what ya gotta do....my setup works acceptably so given the constraints.
Good luck with yours,
Erik
inwall, I just bought all inwalls b/c of my 3 boys...6,2 and 4mths. Heard they sound just as good. Rci85 for front and centers, Rci65 for the sides and rears.
I also have my seats against the rear wall and I'm running fxi a6's and the angle on the fxi speakers work out perfect for me.
Here's a picture of how I'm running my surrounds. The fxi's work out perfectly even with having my seats up against the wall. Bookshelf speakers didn't work as good. Hope this helps.
This is the way I had them when I was running bookshelf speakers. Didn't sound as good with the speakers aiming toward the front vs how the fxi's have them angled at my ears
I have a similar problem as you with my couch up against my back wall. With my old speakers I used to have the rears mounted over my head "behind" me much as in the picture provided by leroy. Another option, which is what I am going to do with my 40's since they are pretty heavy and don't accomodate wall mounting very easily, is to put them on stands next to you, at about ear level.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
wutadumsn23 wrote: »I have a similar problem as you with my couch up against my back wall. With my old speakers I used to have the rears mounted over my head "behind" me much as in the picture provided by leroy. Another option, which is what I am going to do with my 40's since they are pretty heavy and don't accomodate wall mounting very easily, is to put them on stands next to you, at about ear level.
The thing I don't like about running surrounds on speaker stands is if someone is seating on either side of you they will be blocking that speaker. -
thanks for the info but i guess my option is to run the speakers on the ground at a angle and hope they sound good
I also have my couch against the back wall.
For surrounds, I've used towers on 18" stands and then bookshelves on 4' stands. Both sounded great, but I found the towers sounded better as surrounds, possibly because the tweeter and mid were a little lower. Plus it's nice to be surrounded by bass.
The only reason I went with 4' stands and bookshelves is because the stands also serve double duty as bass traps.
Whatever you do, don't put them on the ground."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
poloman1211 wrote: »thanks for the info but i guess my option is to run the speakers on the ground at a angle and hope they sound good
Do you have any pictures so we can see what you're dealing with?
