Sorry George. More dust
12467
  • ben62670
    ben62670 Posts: 15,969
    edited February 2009
    Thanks Bro. They look much better than the pics. I am glad to finally be done with them, and finally glad to have something that isn't a plain MDF box in the living room:) Jerry's tweeters came in today. I can't wait till those are hooked up. They look sweet. I hope they sound sweet:eek:
    Ben
  • Face
    Face Posts: 14,340
    ben62670 wrote: »
    Yes, instead you have monkey coffins with circles on them. :D
  • hearingimpared
    hearingimpared Posts: 21,136
    Hot damn they look nice. One question though; how come the radiators are so low to the floor?
  • engtaz
    engtaz Posts: 7,669
    Ben's usually down there. I'm sorry I could not resist. :)
    engtaz
  • ben62670
    The cabinets happen to work out at 5.3 cubic feet. The optimal cabinet for the 5.5 drivers sealed is 2 cubic feet. I built a z shaped bracket so I could separate the 6 5.5's from the lower chamber. I found a woofer PR combo that is designed to work optimal in a 3.3 cubic foot box:) 2 plus 3.3 is 5.3;) This just happened to work out perfectly for the 5.5 inch drivers in a ported/PR box. The tuning is a hair off on the PR, but that is no big deal. So to answer the question why is the PR so low? It leaves enough room to run an active 12 woofer/PR combo in the lower chamber. The bass is better than I anticipated so I may not run the active 12" woofer. Another option is I have a Dayton Titanic III 15" woofer that does well in a 3 foot box sealed. I could just buy one more for a dual 15" sealed sub setup. I want to be able to run HT without having a separate sub. This is all not in the near future stuff. I want to figure out what I can sell to get the tweeters Jerry ordered. They sound SWEEEEEEEET!
    Ben
  • davidfmartin
    davidfmartin Posts: 106
    Sweet dweet dweet. totally freekin' cool. Can you post picks of the backs?
  • ben62670
    Yes sir!
    The top two post are for the tweeters that are installed. I have some temp wires running to a set of tweeters sitting in some foam "brackets" burning in before the boys get here. I raped a set of AQ type 4 speakers wires :( to wire the woofers internally, and I am using silver plated copper on the highs.
    Edit: I need to vacuum the saw dust, and particles off the floor:o I also need a real work shop. Dust masks will be provided to visitors:eek:
    Ben
  • PolkClyde
    PolkClyde Posts: 662
    That's pretty easy to do IF you have the time :)
    PolkAudioClyde
  • Hobbyguy
    Hobbyguy Posts: 317
    Wow...those are beautiful! Nicely done.
  • zingo
    zingo Posts: 11,258
    The back of those is just flat black laminate then?
  • ben62670
    zingo wrote: »
    Hey Jake the backs are a laminate counter top satin finish. Jerry and I discussed using it for faces in the future for fronts. It is much better looking than the pic suggest. You can find it at HD for $45 a 4x8 sheet. It is nice and heavy duty, and much easier and cheaper than trying to do a painted finish;)
    Ben
  • ben62670
    PolkClyde wrote: »
    If you have had experience building with veneer I am am all ears. It wasn't too bad for me. Some guys have it, and some don't. Like drywall, and plumbing I just can't get it right??? Do you have some links to what you have done? We are having our get together this weekend, and would love to have ya.
    On a side note I have tried many tweeters, and they all have had some sort of harmonic distortion at some frequency. Usually in the upper female vocal range. I am seriously loving these tweeters. I will get a pair some how. I don't care how:eek: These to me have only been surpassed SQ wise by the Focals, but these are very close, can handle power, and are efficient enough to use with SDA's:)
    Ben
    Ben
    SCompRacer Posts: 9,112
    I'm thinkin he meant the cleaning.;)
    Ben, terrific job! High marks!
  • ben62670
    SCompRacer wrote: »
    I could use some tips on that too:D I just looked at the pic, and there are tons of bits and pieces from the wires all over the place. I am going to get some cleaning done. We trashed the place:( We had a lot to do, and a short time to get there. Now our get together has been delayed. This is kinda good. I can clean up a bit, and give the new drivers a chance to break in;)
    Edit: Those 6.5's of Jerry's are more like 7's. They are real beefy. They make my 5.5's look teeny tiny:eek:
    Ben
  • Systems
    Systems Posts: 14,873
    Very Nice,what did you use to trim the veneer around the driver recesses?
    Testing
    Testing
    Testing
  • schwarcw
    schwarcw Posts: 7,358
    WOW! They look awesome! Great job!
    Carl
  • ben62670
    GV#27 wrote: »
    1/2" rabbit bit. The drivers have 3/8" lips so with about 3/32" between the drivers the routed out areas overlap. A little cutting with a razor, and some black paint the recesses blend pretty sweet.
    Ben
  • Systems
    ben62670 wrote: »
    1/2" rabbit bit.
    Ok thanks.
    Again I must compliment you on your work ,they look awesome.;)
    Testing
    Testing
    Testing
  • jerryj12
    jerryj12 Posts: 451
    Looks great. Nice picture. Like...... well you know the rest. :):D
  • Face
    Face Posts: 14,340
    edited March 2009
    GV#27 wrote: »
    How would these work for that application?
    http://www.holbren.com/home.php?cat=725
    image.php?id=725&type=S
  • ben62670
    edited March 2009
    You would want a flush cut bit with a bearing;) Sarah M is singing to me now. Gotta go:)
    Ben
  • jerryj12
    jerryj12 Posts: 451
    edited March 2009
    B.B King now lives in the middle of my living room. :) I hope he don't want to drink all my beer. Thanks Ben, the speakers sound great. What a difference.
  • ben62670
    edited March 2009
    I dry humped your speakers before they left:eek: Yes the sound stage in those is fantabulous! They are by far the best ones yet. I will try to beat them though. Enjoy my brother.
    Ben
    Ben
  • Fongolio
    Fongolio Posts: 3,516
    edited March 2009
    Sweet mother of all things holy...that is some beautiful work Ben! Outstanding.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • ben62670
    edited March 2009
    Fongolio wrote: »
    I do have to say I am proud:) Jerry was definitely a great help with these:)
    Ben
    Ben
  • Ender
    Ender Posts: 603
    edited March 2009
    I hope to one day make speaker that might compare to yours, Ben. Hahaha. Then again, I have never heard your speakers, so I wouldn't know if I could beat yours. Let's just assume I can't. :D
    I need to take some classes on woodworking and electronics soon, I think. I don't really know where to start. Some people are recommending starting with making cables and speaker stands, but where do I look to buy good tools or components? I don't even know what kind of wood to buy... Lol. Or solder or cable ends (Neutriks?).
    Anyhow, I was really posting to say... Awesome work!
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • ben62670
    edited March 2009
    Dude fly in. You have a place to stay. Enjoy the visit, and see what I have done on a limited budget. I am sure you will be impressed.
    Ben
    Ben
  • Ender
    Ender Posts: 603
    edited March 2009
    ben62670 wrote: »
    Ben
    I should... and I might after tax season. But right now I'm on a tight budget (only because I am trying to save up for some insanity called retirement... but thats a ways off for me) so a flight to Georgia might be too much for me. If you were in Arizona or something, I would probably just drive and pay for the gas. Lol.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited March 2009
    Very nice looking Ben. Keep it up.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Pauly
    Pauly Posts: 4,519
    edited March 2009
    Very nice Ben. Hats off
    Pauly
    Life without music would
