Recommend a CD player for my 2 channel
Norm Apter wrote: »Hi Mike,
Is your Jolida modded or a standard/ stock unit. I noticed that the AH! 4000 model is modded, but wasn't sure about your Jolida. Whether it is or not, I was wondering if you put some thought into that when you bought it -- did that play a role in deciding upon the unit that you picked up.
Just trying to straighten out the difference between two types of variables: modded and switching tubes. I know that they mean different things, but am wondering if these two variations speak to categorically different kinds of sound/improvement.
Norm,The AH! that I had did indeed have the "Up-Sampler" installed,I believe this is the main mod. for this player.
I'm not knocking the player,I bought it used and after about 25 hours of use,I had to replace the transport...even when it was working properly I still preferred the sound of the Jolida.
My Jolida is "stock",as you know there are several different paths to mod. this player...one of the drawing cards in my purchase...I just haven't gotten around to send it anywhere yet to have it worked on. -
Mike,, I may need to talk to you,regarding my Ah!,which is on it's way back.I'll wait until it arrives, then I may need your expertise.(transport mech.)JC approves....he told me so. (F-1 nut)
Good questions.
Underwood is the retailer for Parts Connexion, so basically one and the same. I like their mods the best, however I totally disagree with their comments about upgrading the clock.
"We do not recommend upgrading the clock on the JD-100. It voids the factory warranty and dramatically lowers reliability. If anyone recommends upgrading the clock you should call Jolida to verify this and realize that they do not have your best interests in mind."
I fail to see how it could affect the reliability at all unless the replacement clock wasn't of good quality. My player has a Trichord Research clock, which has been trouble free and is vastly superior to the stock clock.
There is no standard, the mod level offerings do vary from company to company. For the money I feel that Parts Connexion offers the best deal.
Thanks for info -- this is all good to know. I'll keep it in mind as I put my next foot forward (still have some thinking to do about budget/needs) and consider what is available on the used market.2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects -
dragon1952 wrote: »If your system is laid back already, the Jolida may not be the best fit. I had the Jolida in a laid back system and, while it was nice, I wasn't blown away or anything. I found a great deal on a Music Hall CD 25.2 thinking I could sell it if I didn't like it, and I ended up selling the Jolida instead.
Thanks for your response.
I'm intrigued... and was wondering if you could elaborate a little more on what you preferred about the Music Hall CDP over the Jolida JD-100. If that takes you too far into esoteric terminology, then I still have one other question for you:
Have you owned or heard the LSi series speakers? If so, I'm just wondering if you feel that your system is laid back in the same way that most people talk about LSi speakers being laid back. When you had the Jolida in, was it a matter of things not sounding lively enough???
Feel free to address these kinds of questions in any way you see fit...as mentioned above, sometimes its hard to convey the differences in words.2 Ch.
HT
Denon 2808ci AVR
Not sure if the group here will like this but it looks like a nice deal to me.It would be mine if I had the funds to spare. http://www.audiogon.com/cgi-bin/cls.pl?dgtltran&1239142060&/Rotel/Meridian/Aav2.0-RDD980/203SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
You might find a used Denon 3910 in that price range. Start saving your Plasma Center dough now Curt.
Thanks for the suggestion Mike.:) That looks like a really nice unit. I've been going back and forth on whether or not I want to get a DVD player, or a dedicated CD player. This is going to be for the two channel rig I'm setting up, so DVD playback isn't necessary.
I like that the audio and video circuitry are completely isolated from each other, which is a concern I've had. I've heard from a lot of people that even the best "audiophile" DVD players aren't going to sound as good as an equivalent dedicated CD player. It does seem like there are a lot of arguments on both sides of the fence in that debate though.
I'll definitely be keeping this one in mind though. It seems like they're going for around 350-400 on Audiogon, which is right in my target price range.
Looks like I've got a few more trips to the Plasma Center to make now.:pThe nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »Thanks for the suggestion Mike.:) That looks like a really nice unit. I've been going back and forth on whether or not I want to get a DVD player, or a dedicated CD player. This is going to be for the two channel rig I'm setting up, so DVD playback isn't necessary.
I don't want to sway you from the 3910, because it is a fantastic player. But that's what I have now, and for whatever it's worth my next upgrade will be to a dedicated CD player as I'm currently of the opinion that a universal player can only take you so far in the world of 2-channel madness.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Well since it is just going to be for a 2 channel system, just get a cd player.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
That's what I'd prefer ideally. It just seems like there aren't many options for SACD players in my price range, aside from universal players. I've found quite a few nice CD players that would fit my price range, but the only one I've found that offers SACD playback is the Sony SCD-C2000ES. That player won't really work for me either because it's a 5-disc changer, and I'm not really a fan of CD changers.
I've still got plenty of time to shop around for them, so I'm not making any decisions yet. I've still got to get my power amp, and figure which pre I'm going to use. The CDP won't be coming along until after that.The nirvana inducer-
Norm Apter wrote: »Thanks for your response.
No, I've never heard the LSi's but I understand the Vifa tweeter is easy on the ears. And I have also heard (read) it compared to the tweeter in my Von Schweikert VR-1s. The combination of my tube integrated and VR-1's are pretty laid back already, and I felt the Jolida might be adding too much more to that? I had the Jolida before the VR-1's, and it worked great in a few of my other systems with the same integrated....with the Paradigm Studio 40's and then later with some Klipsch speakers, and then with some Vandersteen 2CE signatures (which I sold because I was moving out of state and was going to be in a rental for a while.) But once I got the VR-1's, I started thinking about whether or not a solid state CD player wouldn't be more appropriate and maybe add a little 'sparkle' or 'detail'. It added exactly what I was looking for, without **** anything else up. I A/B'ed it with the Jolida for a couple weeks and then sold the Jolida. With these speakers, I can listen to just about any CD in my collection and it sounds great. Some of these CD's sounded terrible on any other speakers I have owned. The CD player has added some missing detail, and it has a very 'liquid' sound in my system, like the Jolida. I can't say enough good things about it. I got a crazy deal on it ($375 shipped brand new) or I might not have tried it. But if this one busted or was stolen I'd buy the same one again. Something was just missing with the Jolida, and I thought it might be too many tubes in the mix. Plus, while rolling tubes was fun at first, after a while you still wonder if you've got the optimum tubes in there. Anyway, I know you don't have tubes, but if you think your system is laid back already then a solid state CD player might be the way to go....or maybe not. The good thing about the Jolida is, if you're patient, you can usually find a great deal on a used one and always get your money back. But if you go solid state, before I spent $700-$1000 for one I'd find one of these used for $350-$400 and see what you think. You don't seem to see many used though, which should tell you something. I know it doesn't have that big name appeal, but they are sweet little players.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
I firmly believe it all starts with the source.....garbage in, garbage out. Have you ever considered that aspect?
+1. I'm not sure of the guy's budget limits but he should audition the NAD M5 SACD player. It's multi-channel capable but is designed for a 2ch. setup. I believe the source should sound as neutral as possible. Let the amp and/or speakers determine the tonality. -
[QUOTE=F1nut I firmly believe it all starts with the source.....garbage in, garbage out. Have you ever considered that aspect?[/QUOTE]
Completely agree.
The first source is the artist then the recording engineer then the media, lp, tape , cd and FM...... -
Ideally, every part of the chain should be neutral, so you can hear what was intended, not something that has been distorted by a component in the path. The generic phrase for a hi-fi system used to be "a wire with gain", but we all now know that wires also distort the signal in some manner.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Makes perfect sense. Everything distorts to some extent. The question may be is the distortion audible or not. -
Quad 99CD-P/2 CDP (Solid State).
Mentioned in this thread.
http://www.polkaudio.com/forums/showthread.php?t=44125&highlight=quad
Carl (schwarcw) has it now.
Higher than your used specified budget. No affil with this one, there are more.
http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1240509090&/Quad-99-CDP-2-CD-PlayerSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Or, whether you like the distortion. This is why you hear things like "it sounds warm", "it's laid back", "it's harsh", etc. etc.Lumin X1 file player, Westminster Labs interconnect cable
I remember auditioning a pair of LSi-15s against a more expensive pair of Focal Utopias. The Focals produced a more forward, holographic 3-D sound. Polk ring radiators seemed to hold back the sound--warmer yes but not as dynamic? Just my two cents.
Polks probably needed a LOT more POWER than the Focals, I suspect!
IMO, it's the crossover that holds them back, not the tweeter."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Do what the rest of us did when first starting out. Understand the worth of an audio forum and then realize that all the opinions given are just that and most of them are not even founded on listening experiences but taken from what people have read or 'heard about'.
You'll be a lot further ahead when you figure that out and you'll build a better system, you'll likely stop upgrading as much having heard wtih your own ears what certain components sound like. Everything else is an opinion and that and $1.50 will get you a cup of coffee or maybe a bus ticket. -
I was considering the 3910 for a while, but I think I've basically ruled it out. I've got a different plan now. I think what I'm going to do is get one of the Oppo universal players to use in my 2 ch. rig temporarily. It's not the greatest, but I'll be able to use it afterward anyway as a DVD player when I set up a bedroom rig. I could always sell it to help fund a CDP as well. For their price point, it's hard to beat the quality. I've heard a lot of good things about the Oppo's.
It'll be a temporary CDP in my 2 ch. rig with my Fisher 332, until I get it more or less setup with the amp and pre that I want. After the pre and the amp have been purchased I'm going to start saving up for a nicer SACD player somewhere in the 700-900 range. Right now the one that I'm considering is the Marantz SA-8003 SACD player...It looks like a very solid player, and I've heard a ton of praise for it. It fits nicely into that price point too, going for about 750 or so.The nirvana inducer-
Face, I believe that he's correct. The Focal's I have are 8 ohm whilst the Polk's are 4. If I'm not mistaken, the sensitivity is a tad higher on the Focal's as well. Add to that the fact that the pure Beryllium tweeter is just so revealing and you have a sense of the Polks being power hungry in comparison.Polks probably needed a LOT more POWER than the Focals, I suspect!
I don't know about that on this forum........and then realize that all the opinions given are just that and most of them are not even founded on listening experiences but taken from what people have read or 'heard about'.........
Sorry for the derail. Now back to our regularly scheduled program folks......~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
comfortablycurt wrote: »I was considering the 3910 for a while, but I think I've basically ruled it out. I've got a different plan now. I think what I'm going to do is get one of the Oppo universal players to use in my 2 ch. rig temporarily. It's not the greatest, but I'll be able to use it afterward anyway as a DVD player when I set up a bedroom rig. I could always sell it to help fund a CDP as well. For their price point, it's hard to beat the quality. I've heard a lot of good things about the Oppo's.
Save your money by not buying the Oppo and get a dedicated CDP. I'm talking from experience here. I had an Oppo paired with a $4000 DAC and it just did not get me THERE. What got me THERE was getting a Raysonic CD 168 tubed CDP. This is in my two channel rig.
I do however have that same Oppo model as a source for the HT rig. -
hearingimpared wrote: »Save your money by not buying the Oppo and get a dedicated CDP. I'm talking from experience here. I had an Oppo paired with a $4000 DAC and it just did not get me THERE. What got me THERE was getting a Raysonic CD 168 tubed CDP. This is in my two channel rig.
That's what I keep thinking that I really should do...It'd save me a couple hundred bucks in the long run. I'd have to have my Cambridge hooked up to both the 2ch. rig and the HT setup though if I went that route. Would there be any reason I shouldn't do that? I'd have it hooked up to my Onkyo AVR with a coax audio cable, and to the two channel with the analog outputs. I would assume that'd work fine, any reason it wouldn't? Obviously I wouldn't be using them both at the same time...lolThe nirvana inducer-
comfortablycurt wrote: »That's what I keep thinking that I really should do...It'd save me a couple hundred bucks in the long run. I'd have to have my Cambridge hooked up to both the 2ch. rig and the HT setup though if I went that route. Would there be any reason I shouldn't do that? I'd have it hooked up to my Onkyo AVR with a coax audio cable, and to the two channel with the analog outputs. I would assume that'd work fine, any reason it wouldn't? Obviously I wouldn't be using them both at the same time...lol
I use my Denon 3910 in that fashion right now. Analog out to my preamp when in 2-channel, and digital coax out to my receiver when in HT. It works just fine.Speakers: Polk LSi15
The Cambridge has a good dac in it and it has SACD. You are fine with that piece for awhile until you can afford to go way up the audio chain. You should get everything else you need now and worry about a stand alone cdp later. For what I sold that to you for you should be very happy with the "jump" you got from that.
Don't get me wrong, I'm still very happy with the improvement that the Cambridge made, especially for the price you gave me. The sound quality from it is leaps and bounds better than what I was using before. It's going to spend a whole lot of time in my HT setup before it gets upgraded again. Thanks again Dave.:)
In either case, I'm planning on picking up the speakers for my HT setup, and getting a pre-amp and power amp to get the 2 ch. rig going before anything else. I'm just trying to figure out which direction I want to take as far as the CDP for the 2 ch. goes. A dedicated CDP probably won't be coming around until next year though, so I've still got some time to decide on one.
Now that I've thought about it some more though, what I'll likely end up doing is connecting the Cambridge to both of them for the time being. I'll just run a coax from it to the Onkyo, and the analog outs to the 2 ch. rig. I'll just do that until I can afford to get a better stand alone CDP that's going to work for me.
I don't want to spend the extra money on another universal player, when I could just put it towards the pre and the amp that I want.The nirvana inducer-
SCompRacer wrote: »Quad 99CD-P/2 CDP (Solid State).
Hey Rich,
Nice looking player. I went back and read the thread, but I'm wondering if in the mean time either you or Normanality (great user name, btw:)) got a chance to use it with SS gear.
Made in the UK, right?...like Rega.
The budget is somewhat flexible...but unfortunately its a budget for some time in the near future (need to get my hands on my tax return first:D)2 Ch.
HT
Denon 2808ci AVR
The crossover can be changed (by someone who knows what they are doing), right?, though of course voiding the warranty.
Just out of curiousity ...and I'm sure that there are threads on this somewhere...but I'm wondering if you or others have had the chance to hear modded Lsi9s (or 7s).
Probably opening a can of worms here, but I'm just curious...its not like I would plan on doing it or anything.2 Ch.
HT
Denon 2808ci AVR
I've heard(and modded) LSi9's and a LSiC and can tell you that they do sound much more open and dynamic with better caps. I should be getting my hands on a pair of LSi15's soon too."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
but I'm wondering if in the mean time either you or Normanality got a chance to use it with SS gear.
No, all tube and just tube pre. Carl has it in an all SS system, but I cannot recall the components. In his system, he felt it needed a tube buffer. I'll ask to see if he wishes to explain why.:p:DSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
