Rotel 1090 or Class A
Saummisra
Saummisra Posts: 7
edited February 2009 in 2 Channel Audio
Hi
Need your help on :confused:this. Iam getting a slightly used Rotel 1090 for about $750 from a friend (special deal I think they go for about a 1000). I was wondering if I should go for this or I should go for a Class A pair (such as a Monarchy SM70 pro pair). Is Class A really that much better? I've never heard it so would like to hear your views.
Post edited by Saummisra on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I can't really compare the two types, but that is a killer deal for the 1090. I've been watching them lately and they typically go for around 1000-1200 dollars. They're fairly hard to come by too.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • organ
    organ Posts: 4,969
    Try to give them a listen first. There are good and bad examples of each. I doubt you won't be satisfied with the Rotel. You're getting a great deal and a killer amp.
  • Saummisra
    Saummisra Posts: 7
    Thanks guys
    I thought Monarchy would sound better but I have no idea what it sounds like ( i listen to rock mostly)..I can't drive the 1090 hard at all. The last time I pushed up my current Rotel RA 980 the guy from downstairs came up to introduce his dog.. but i could buy it and sell it later.. though I don't know if it is too much of a risk since I assume not many amps would be selling.
  • Saummisra
    Saummisra Posts: 7
    Also is Class A really that different?
  • Saummisra
    Saummisra Posts: 7
    Sorry I am connecting them to, believe it or not, B&W 602s tiny little speakers
  • CRESCENDOPOWER
    CRESCENDOPOWER Posts: 153
    This is great thread! Whatever you decide keep in mind that Rotel, and B&W are famous for synergy. Depending on the rest of your system, and your philosophy of what you want to achieve overall within your setup think long and hard before spending one penny. If you are not setting your bookshelf speakers on good stands, seating yourself in the sweet spot at ear level, and looking right into the image I’m not for sure that an upgrade in an amplifier would, or could be your best choice.
    Overall, you have received excellent advice from everyone within this thread, and I got this one on subscribe.:D
  • leroyjr1
    leroyjr1 Posts: 8,785
    I'd say give it a try. If your not satisfied with the 1090 in this case since your getting it so cheap you could sell it and make a profit .
  • Music Joe
    Music Joe Posts: 459
    You said "slightly used" and "from a friend". If said friend bought new you may have the balance of a 5 year warranty. B&W and Rotel are said to have good synergy.
    heiney9 Posts: 25,488
    Class A all the way............the Monarchy's are outstanding and would be a better choice musically than the Rotel.
    Here's a couple of great articles about class A (true single ended class A). Do yourself a favor and read them. The first one being the most informative
    http://passlabs.com/pdf/articles/seclassa.pdf
    http://passlabs.com/pdf/articles/leaving_class_a.pdf
  • Saummisra
    Saummisra Posts: 7
    It seems that class A would be better.. though I've heard that many well designed Class A/B amps (such as Rotel) will be better than ordinary Class A amps.. also wouldn't the Rotel probably operate in Class A fr say the first 30 watts or so?
  • mantis
    mantis Posts: 17,556
    Saummisra wrote: »
    The rb1090 is more power then they will ever need. You can use the rb 1090 to power any speaker in the 800 series including the mighty 801's with no problems. For that price it's a no brainer, I would jump at that deal.
    Dan
    Dan
    Saummisra wrote: »
    The Monarchy's are not ordinary class A; really there is no such thing as "ordinary" class A. Some older hi fi companies stretched the truth on class A operation and weren't true class A. They were all still push/pull type topologies.
    No, the Rotel doesn't run in single ended class A. It runs in push/pull A/B and may be biased to run a couple watts in the class A range. Single ended class A is a completely different animal.
  • phipiper10
    phipiper10 Posts: 961
    heiney9 wrote: »
    Me read so many big words me still confused.
    You have to have a decent foundation already to understand a lot of what is written. I get some of the concepts but I can't understand the "why" so much. The words aren't foreign but the meaning on each individually is a little lost with me.
    The below are not words I throw around everyday.(Guess I'm still a noob)
    Single ended
    Pentodes/Triodes
    Real Life Bias
    Current/Amp (even current and amp)
    FET/FET/FET - J/MOS/T
    THD
    Push/Pull
    Bipolar power devices
    Gain
    transformer coupled single-ended triode
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
