SDA SRS 2 Crossover Parts list
Good luck, I'm interested to see how this turns out."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Disc Jockey wrote: »Good luck, I'm interested to see how this turns out.
Well, if our assumptions, interpretations and educated guesses are right, It should be $#@^&*' FANTASTIC!
I have some "Best of Eagles" on right now going back and forth A to B between my SDA-2B Sonicap'd "TL's" and my SDA SRS 2 RDO194-1 Sonicap'd speakers, and both simply blow me away. However, I have new MIT Shotgun 2 IC's and Cables just approaching 48 hours of burn-in on the SDA SRS 2's and the sound already has a hallucinogenic effect. 300 more hours of burn-in to reach full effect, and with RDO198-1's, I don't know what I will do. I'm afraid my addiction won't allow me to leave the room :eek:.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Likewise I hope your efforts are fruitful.Testing
Testing
Testing -
I'm now wishing I didn't solder everything together on my 2B TL's..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Meaning the tweeters and mids? I don't think there's much to improve after the crossover mod unless you go from all Sonicaps to Mundorfs on the 5.8 and possibly the 12uf. I actually had a chance to listen to a pair with Mundorfs in the 5.8 spot, and like the warmer Sonicaps there better.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
I soldered because of the different connectors between the 194 and 198.
And you can still improve from Mundorf caps...
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Ha! and I caught hell for my hack in post #61 at http://www.polkaudio.com/forums/showthread.php?t=74945 when I faced the same obstacle (this rookie isn't as dumb as he sounds
). I later found some high quality adapters and replaced the radio shack crap I originally used.And you can still improve from Mundorf caps...
Like the plethora of caps photographed in a frying pan on the website I've seen F1 post (can't find my bookmark right now) ?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Thanks. That's the link! I won't forget it again.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
I don't think I can take this guy seriously. I mean he hasn't even tested the Dayton's
Ben -
Yeah, but he tested the Duelund CAST Copper Capacitor. I thought, heck, what if I got a couple 5.8uf's to finish my SDA SRS 2 "TL" mod instead of the $14 each Sonicaps I have coming tomorrow.
Well, they only come in 5.6, and they're only $450 . . . . EACH!VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
I have driven cars that cost less than that:eek:!!! I am driving one now:oPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ditto. My wife and girls get the good cars. My caravan turns 16 on Monday and is worth 1 of those caps. I did buy it new in 1993 and it was worth a few more caps then
NAD SS rigs w/mods
GIK panels -
I'm not sure if Daytons compare to a majority of them.I don't think I can take this guy seriously. I mean he hasn't even tested the Dayton's
Before he published his review, in a email I asked him about the Claritycap MR's and Dayton caps. His response included his impressions of the MR's(which mirrored mine), but he left out anything about Dayton."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Actually, Duelund will make just about any size cap value you want.Political Correctness'.........defined
President of Club Polk -
I figured as much, just being a little facetious. Those better be some fine sounding caps!
I think Ben was being a little sarcastic also about the Daytons.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Well, Solen made the list, so I'm a little surprised Dayton(Bennic) isn't on there also."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
5.8uf Sonicaps arrived and I went to desolder, and my old desoldering iron is dead. I'm running to local Radio Shack. Hopefully I can get this done today.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Are you just swapping the 4.4uf with the 5.8uf?If so I'm guessing the change will be rather subtle as only the response in the top octave will/should be altered.inspiredsports wrote: »5.8uf Sonicaps arrivedTesting
Testing
Testing -
As in my post #94 above, Yes.
I wrote, "Agreed. In rereading everything over and over today, Matt simply could not have been talking about the 2.0 ohm resistor position. There are three 2.7 ohm resistors on the circuit board and he chose his words to single out the 2.7that was not sequenced with an inductor.
5.8 caps arrive Friday so sometime this weekend I'm going to desolder the 4.4uf cap, solder the 5.8uf in its place, replace just the top tweeter with an RDO198-1, leave the RDO194-1 in the bottom position alone, button it back up and give it a listen.
After a good listen I will swap out the lower 194 with a 198 to see if that yields any improvement."
However, the RDO198-1's make a HUGE difference in my SDA-2B's so I don't believe the change will be "subtle".VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
My "subtle" remark was only in regards to the capacitance change.Changing drivers is a different matter.inspiredsports wrote: »However, the RDO198-1's make a HUGE difference in my SDA-2B's so I don't believe the change will be "subtle".Testing
Testing
Testing -
got it!VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
No worries you won't have damaged the inductor(s).After all they are just coils of varnished copper wire.Testing
Testing
Testing -
I've been listening to my SDA SRS "2.05 TL's" for just over an hour now and have to say I am very, very pleased. The SRS 2's lower treble quantity and quality with the 194's (versus my TL'd SDA-2B's) was really bothering me. That concern is now absolutely gone!
I've dubbed this first mod "2.05 TL" as after changing the 4.4uf bypass cap to a 5.8uf, I have only changed out half (the top position) of the tweeters from RDO194-1's to RDO198-1's. I am still using the RDO194-1 in the lower tweeter position.
I can unequivocally state that this mod (one 5.8uf Sonicap and one RDO198-1 per cabinet) is absolutely "enough" to make anyone contemplating it happy without having to spend the extra dough for all 4 RDO198-1's.
I want to listen to a lot of different music before the next step which is changing out the lower tweeter to the RDO198-1 and bringing them up to a full SDA SRS "2.1 TL".
I will be doing a lot of side by side listening with my SDA-2B TL's as a reference as I make changes.
I've included a photo.
NOTE: The 5.8 cap is a bit larger than the 4.4 and you have to be very careful not to exceed diameter of the circuit board by much or you will have trouble reinserting the crossover into the hole in the cabinet as there is very little clearance.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Good to hear. Have you done anything with the first resistor? Do you have an SPL meter? You may want to use a signal generator to figure out if the is a dip or bump between the two tweeters. It takes a lot of listening to different music to find a bump or a hole. Many times I have thought I had things figured out, but I drop in another CD, and someting was wrong.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I have 2 brand new 2.7 ohm Mills Resistors here, but I'm in no rush bump the volume of the circuit up yet. I have a pretty good quality calibrated db meter, and have already been playing with it
NAD SS rigs w/mods
GIK panels -
WINisd has a built in sound generator. I do like being able to tweak the XO yourself in home. Its like having a tone control:eek::) I know its very hard to resist, but let those caps burn in for a while before you start playing. This will be a great hands on learning experience for you.
Take care.
Ben -
. . . let those caps burn in for a while before you start playing. This will be a great hands on learning experience for you.
Take care.
Ben
Exactly, I'm back in that 24/7 burn in mode that I thought I was finished with a couple of weeks ago. 3 hours down, 397 to go :eek:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »I've been listening to my SDA SRS "2.05 TL's" for just over an hour now and have to say I am very, very pleased. The SRS 2's lower treble quantity and quality with the 194's (versus my TL'd SDA-2B's) was really bothering me. That concern is now absolutely gone!
That sounds great, congrats!"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
