PCM 2 channel vs Dolby true HD is something wrong?
bevo
I just bought the Dave mathews and tim reynolds at the hard rock cafe blue ray. It has PCM 2 channel, dolby digital, and dolby true HD 5.1. The true Hd sounds pretty good, but the PCM sounds like crap. Could my ps3 be messing up the PCM somehow. I don't have any other PCM 2 channel disks to listen to. And I really like my music in 2 channel better.
When I switch to the PCM everything distorts very easily, vocals, guitars, everything. The concert isn't the greatest recording ever, but it is a great live recording. It falls a little short of the luthern college sound, but it is good.
Anyway, why would the PCM sound so bad?
Has anyone else had any trouble with the PCM 2 channel on the ps3?
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Post edited by bevo on
I've done some more listening to the disk, and I think it's just a horrible mix. Even in true hd the audio is still hissing and crackling. I almost think I got a bad copy or something. The reviews I read about it, all said it was the best audio they had ever heard on blue ray.
Maybe I'm wrong, but if anyone else has this blue ray, please let me know how yours sounds.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Buttkicker(don't use or need it anymore since getting the Ultra) -
I think there are some audio settings on the PS3 that boost audio levels - I can't remember exactly what they are called.
You may want to go into your PS3 settings to see if you can find the audio levels and adjust them down - sounds like the PS3 is set to boost the levels into overdriving which is causing the bad crackling you are hearing.
Erik
After playing with everything more, I'm just sending the disk back to amazon. There is no way that it should sound like it does. I have never received any kind of disk, or heard of anyone receiving a disk with corrupted audio on it, but hopefully that's what's wrong.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Go into the audio setup on your ps3 and set it to bitstream.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
I noticed some distortion on The Dark Knight and I honestly had thought I had damaged my system. It turns out, somehow the volume control got boosted up to +2 or whatever the highest setting is which was overmodulating the signal before it even hit the receiver.
It is kind of hard to see but you want to hit the triangle button during playback, go to the speaker icon and make sure to set it to unity gain. (0)Go into the audio setup on your ps3 and set it to bitstream.
That will force the receiver to handle the decoding and it will limit the audio to AC3, DTS, and 2CH PCM and he says it is distorting on all formats.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection
