Speaker Wire
Friend of mine said he use's ext. cord for his wires but i'm thinking thats not the best thing ....i mean hell ext cord is there for elect. power not sound ...ooo yea like to have some wire not to hit the old wallet to hard lol
Post edited by Stitchxx on
Monoprice.comRetired Onkyo 520 (returned broken HK 247)
Now a Pioneer 1018
CSi3
2- RTI10's
2- R50's
2- Fxi3's
Onkyo 250W Sub
Polk psw-10
"Inch by inch lifes a cinch, yard by yard life is hard" -
I've actually gotten good results from 12 g outdoor lighting wire. Paid about $9.00 for 50 feet and the sound was quite impressive.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Signal cable,, tell Frank that you are a CP member,,good reliable cable.JC approves....he told me so. (F-1 nut)
Did you really say he's a friend
You have lots of options so use them. Like George said, Signal Cable for quality cables are hard to beat. If you are real budget conscious start with Mono. -
Blue Jeans cable another alternative.Do you hear that buzzing noise?
Wire is wire, the only property you need to be concerned with is the Gauge. Make sure it's adequate for the length of run you have.
http://www.roger-russell.com/wire/wire.htm_____________________________________________
Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R -
williamgauci wrote: »Wire is wire, the only property you need to be concerned with is the Gauge.
Oh no, you didn't go there did you? Here we go again.;) -
Did that can of worms seriously just get opened? :eek:
I'm out of here! lol
this can be a very volitle subject! Just go with monoprice!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
williamgauci wrote: »Wire is wire, the only property you need to be concerned with is the Gauge. Make sure it's adequate for the length of run you have.
william william william
:(OK, Sorry everyone, i've been lurking around here for years and haven't really contributed. I know how volatile this subject is and this is akin to the Bose debate. But I think the emperical evidence suggests that at best there is a marginal improvement when comparing the same gauge wire in blind tests.
Having said that, the OP made the statement that there must be a difference between wire produced to carry electricity and one designed to carry sound. The signal travelling from source to speaker is electrical isn't it?
I will now go and live in shame.
george daniel wrote: »Signal cable,, tell Frank that you are a CP member,,good reliable cable.
Never owned Signal but after just checking their website and realizing they are made in the USA, I may try out some of their products.
Very good prices and shipping is cheap as well.;)
All I need now is some money.:eek: -
williamgauci wrote: »:(OK, Sorry everyone, i've been lurking around here for years and haven't really contributed. I know how volatile this subject is and this is akin to the Bose debate. But I think the emperical evidence suggests that at best there is a marginal improvement when comparing the same gauge wire in blind tests.
william
No reason to go in shame and no reason to say your sorry but...........
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Are the MTI Terminators 4, 2 etc. any good or any better that regular 10 or 12 gage speaker wire?
I too owned Mono price 12gauage and recommeded them often. A good deal came up here a couple of weeks ago for a pair of AQ T4s and I thought if cables can make a difference these should be good enough to notice the difference and I would try them to see, if I could not tell a difference I would simply offer them up here for what I paid for them.
I was prepared to not hear any difference, I almost did not want to because money is tight.
All I can say is they are not coming out of my system for a long time. Vocals were better centered and sounded to raise up about 2 feet, bass was dramtically tighter. Highs were a bit clearer and sharper but not as dramtic as the vocals and bass.
YMMVSpeakers: SDA-1C (most all the goodies)
What happens with unreliable cable?KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Unreliable cables often say that they are going to do something and then don't. More seriously this is probably referring to the quality of construction and lack of defects. The most obvious defects would be shorts due to frayed strands of wire or compromised insulation. The converse is high impedance and opens due to poor crimps, soldering, broken conductors or low spring tension on the connectors.
Beyond the defects, there is the quality of the insulator and quality of the conductors.
Hope this helps
StanStan
Main 2ch:
HT:
Other stuff:
it will certainly work, but not something I would do.
another is www.parts-express.com -
i hate it when they do that.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Better by leaps and bounds. -
Oh boy....Ok,if you have,lets say,monitor 30's with a sony low end cdp,and a 500$ AVR,then no,you probably won't hear a big difference.When your gear starts getting better,along with your speakers,the more cables will play a role in the quality of sound you get from your system.Look at most members here,or on other audio forums,and you'll see when they move up the chain in their gear,they also move up in cables.There is a reason for that ya know.While regular 12 ga. home depot cable will suffice for alot of stuff,it won't cut the mustard when you start getting into the RTI line an above.Everything has it's usefull place in audio.HT SYSTEM-
lsi 9's -
;;;;;........my 4 cents. Start with 12 gauge extension cord or Monoprice. Get your system together where you like it....then tweak it with the wires.
This is probably THE best advice Ive read on speaker wire!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I was thinking about removing the huge power lines in front of my house and using them as speaker wire. What are those? Like 000 Gauge?...lol
Wire is wire, so yes, lamp cord or extension cords will work. There is a reason that not many people use them though...lol...There's a lot more to wire than just gauge. People are willing to spend hundreds, even thousands of dollars on speaker wire for good reason.
As TonyB said, it makes more of a difference depending on the equipment your running. If you have a Sony HTIB setup...going out and getting MIT Oracles to hook them up with isn't going to really give you much of an improvement. If you have some higher end gear though, the wire that came with your Sony HTIB isn't going to cut it.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Curt, im looking at stepping up to the Onkyo 606, how do you like yours?Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I'll second that. I can't believe the lack of cable knowledge in this thread. Roger Russell. Damn it. I said I would scream the next time I heard that name. Kids are home. I think I'll go kick a chicken...Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I was **** slapped the last time i used the R-R name! LOL!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
That guys name sure does raise some feathers. Maybe because he knows what he's talking about & we simply choose not believe a word of it. His wallets probably a lot fuller than ours. After all if someone dropped a cool $grand$ or so on some speaker cables...you damn well better believe he's going to hear a difference. Or at least he'll keep telling himself that over & over again until he actually does believe it. -
Phil after trying many cables it's obvious they make a big difference. The most surprising recent example was using different IC's with SDA's. The SDA effect was totally gone with one set of IC's. My buddy and I thought that there was something wrong with the speakers. We swapped out the IC's and the SDA were back in full effect.pearsall001 wrote: »That guys name sure does raise some feathers. Maybe because he knows what he's talking about & we simply choose not believe a word of it...
Ben
