Polk RM 510
msoghaier
Just bought these speakers as display units, no instructions came with. There are two smaller ones (rm7)and two larger ones (rm8). I just need to know
1. which go front and which go rear?
2. where I can get the wall mounts for them?
3. Driving these with onkyo sr506 receiver. How much power to front/rear?
4. Where can I get the owners manual online? Couldn't find it at polkaudio
Can someone advise.
Thanks.
Can someone advise.
Thanks.
Post edited by msoghaier on
ms, welcome to CP. I think some kind of wall bracket were supposed to come with those. Anyway here are some links for you.
spec sheets here
manual search here
Are you sure you have that RM510 is correct? You may need to find everything for each RM7 and RM8 individually.
The speakers with the most capabilities would go up front (RM8) but it is not cast in stone. If for some reason the RM7 fit better for you up front give it a try. Remember this is your sys. so you can do what ever sounds best to you. Don't be afraid to try things out.
Those should be pretty easy to drive so the Onk should do it, but I am not familiar with that model, so maybe others will chime in. -
Thanks for all the good stuff on this sys. I can't wait to nail em into the wall and fire em up.
The brackets did not come with the sys, but I should be able to get them off the polk site.
best,
MS -
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=3012&seq=1&format=2
you can try these available in white also, these guys have one of the best CS.;) -
+1!http://www.monoprice.com/products/pr...seq=1&format=2
Odd, with most packages the wall mount are included... I guess lowering their cost is the way not to increase our cost and beat the economy crisis!DARE TO SOAR:
+1!
Just to clarify, I think the OP bought a floor model set-up, where the brackets, etc. got chucked by the store?I refuse to argue with idiots, because people can't tell the DIFFERENCE!
