MIT speaker cable question
Polkitup2
Polkitup2 Posts: 1,642
edited February 2009 in 2 Channel Audio
I have monitor speakers on stands and was wondering if the MIT shotgun network boxes are too heavy to just dangle from the speaker inputs?
Post edited by Polkitup2 on
  • Ricardo
    Ricardo Posts: 10,634
    I had mine "hanging" from my monitors and the cable bent pretty hard at the terminations; not sure how much stress this could be, but if you can find something to reduce the weight, do it. I thought of attaching the boxes to the stands (tape, rubber bands, anything), but never did it.
    SOPA
  • janmike
    janmike Posts: 6,146
    I have MIT Shotgun S1's and had the tails made longer so the network box sits on the floor. Too heavy IMO.
    Michael ;)
    NORTH of 60°
  • Face
    Face Posts: 14,340
    Unless you're hooking them up to cheapo speakers, it shouldn't be a issue. And then again, it wouldn't be your only issue either.
  • Lsi9
    Lsi9 Posts: 616
    Velcro the box to the stand
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Polkitup2
    I'm thinking that might be best.
  • hearingimpared
    hearingimpared Posts: 21,136
    When I tried to Velcro mine to the cabinet, it put more strain on the binding posts by forcing a more dramatic curve in the wires at the banana clips. If your binding posts are solidly installed they should be able to handle the weight of the network boxes.
    F1nut Posts: 51,912
    I've got a pair of MIT's hanging off the back of my office monitors. Been like that for years with no problems.
  • inspiredsports
    inspiredsports Posts: 5,502
    Call or email MIT to be sure, but I'll bet hanging is OK.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
