AQ Type 4 Bananas?
Polkzilla
I'm thinking about giving these cables a try. I have seen what looks like two different styles of Bananas on these. Is one better than the other? Am I seeing things? Thanx.
Post edited by Polkzilla on
After some more research, they come with a BFA Banana and the other more "normal" banana is an alternate. Again, can anybody chime in with the difference? -
You should put yourself on the demo list offered by NJPolker.
There are several of us "Polkies" who are going to try out a set of the AQ Type 4s for ourselves.
NJPolker is going to re-terminate a pair with bananas for all of us to try.
fwiw,
Erik
I just bought these cables with BFA bananas, never having used those I was leary but they plug into my Carver just fine, nice and snug.
I think they act like a spring.Speakers: SDA-1C (most all the goodies)
I had both and the regular style connectors did not work with my amp or speakers. I switched to the BFA's and they are perfect. The BFA's are the premium banana.
Venom
