CRS speaker stands
hoosier21
I did a search, didn't find what I needed, ok I am lazy also.
There is a post on this forum showing the dimensions of the stands Polk sold with these speakers.
Can anyone find it? Or hell if you have a set, can you post the dimensions.
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
This what you were looking for?
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=5163&highlight=sda+crs%2A+stands -
I'd say that's it. Good job.
While we're on the subject. Anybody know the dimensions of the original Monitor 10 stands?Make it Funky!
Are these them? Not sure if these are Polk stands, but that is what I have with my Monitor 10's.
Could be, but I'm not certain. Is there a slope to them? Could you measure them up whenever you get a chance? No hurry though as I have many projects on my plate at the moment.
Thanks!Make it Funky!
My god thats a crappy pic, even for my crappy camera.
I sincerely appologize for that
There is a slope to them.
I will take some measurements in the morning and report back to you.
Mike -
Mark,
Here's an excellent replacement (I consider it an upgrade) stand for the Monitor 10's. The pic doesn't show it, but they have a 20 degree angle on the top plate. There is an 8" and 12" version.
http://accessories4less.com/aless4/Corporate/itemdesc.asp?CartId=12177125HCDXJ-ACCWARE-85&ic=SD%2DBB50%2F8&cc=&tpc=
Cheers,
Hoosier,
You used to have two sets of stands... you sold me one and God knows what you did with the other. What's going on? Speaker-confusiciousness?
Just Curious. -
I sold the other set to somebody on here a long time ago.
I have a set of CRS+'s and was thinking of making a a pair of stands from wood. Or maybe even having a set made for me out of square tube.Dodd - Battery Preamp
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thanks Mike. Overall measurements would be fine as if I build them I'll make them a little different.
Thanks Russman. Those look much better than what I'll probably end up with. I bookmarked it just in case I get frustrated.Make it Funky!
Hey Gidrah-
Sorry bro forgot about this altogether.
Here ya go-
The top plate:
Is 8 9/16" x 9 13/16"
by 1/2" thick.
The two little supports (vertical) are:
5" x 5 11/16" at the higher end, by 3/4" thick and spaced 15/16" apart.
The bottom plate:
11 10/16" x 11 10/16" by 3/4" thick.
The top plate sits 1 1/2" back on the vertical supports.
If you need anything else, post here or I have AIM, Surfbum072.
Take it easy. Mike -
