onkyo 800 default settings
brentski
brentski Posts: 96
edited June 2003 in Electronics
Does anyone here know how to re-set an Onkyo 800 receiver to it's default settings? Something's got screwed up with the DSP functions and I'd like to revert back to the way it was out of the box.
Any help would be greatly appreciated.
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited June 2003
    Usually there is a microprocessor reset function that wipes out all screw-ups and resets everything to the factory defaults.
    In my 3803, you have to unplug it, and then plug it back in with the power button held down until the display flashes continuously (or something like that).
    The oink probably has a similar deal - check the OM or call tech support.
    Doc
    SVS
  • kberg
    kberg Posts: 974
    edited June 2003
    This is for the Oink TX-SR600, but it may also work for you:
    Hold down the VIDEO 1 button with the unit turned on and then press the STANDBY/ON button. The word "CLEAR" may appear on the front display and the unit enters the standby state.
    Let me know.
    KB
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
