onkyo 800 default settings
brentski
Does anyone here know how to re-set an Onkyo 800 receiver to it's default settings? Something's got screwed up with the DSP functions and I'd like to revert back to the way it was out of the box.
Any help would be greatly appreciated.
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
Usually there is a microprocessor reset function that wipes out all screw-ups and resets everything to the factory defaults.
In my 3803, you have to unplug it, and then plug it back in with the power button held down until the display flashes continuously (or something like that).
The oink probably has a similar deal - check the OM or call tech support.
Doc"What we do in life echoes in eternity"
SVS -
This is for the Oink TX-SR600, but it may also work for you:
Hold down the VIDEO 1 button with the unit turned on and then press the STANDBY/ON button. The word "CLEAR" may appear on the front display and the unit enters the standby state.
Let me know.
KBMains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
