Info on shunt caps for Adcom GFA-545?
nadams
Can I do the shunt cap mod on my GFA-545? If so, what type of caps do I need? I'm very familiar with capacitors on computer motherboards, as I've replaced scores of bad ones. Audio caps, on the other hand, baffle me.
See here for pics of a 555 with shunt caps installed - http://www.polkaudio.com/forums/showthread.php?t=76378
Thanks in advance,
Noah
Thanks in advance,
Noah
Ludicrous gibs!
Post edited by nadams on
You can easily do the mod. All you need is some 100v or better film caps like you would use in an XO. Now what values you use are controversial. I like either 12uf, or a combo of 20uf, and 1uf paralleled. I will be doing this mod soon. I had a 555 with the mod. I take a look at the schematic to see if there are any input caps that should be replaced. Shoot me a PM if I don't post an answer by this evening.
Ben -
So then, I'm looking for something like this, right? - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=027-430
Would I need 2 or 4?Ludicrous gibs! -
4, one by pass per main filer cap.
I did this before I shipped my pair of GFA-555's the new happy owner.
This is a low cost way to give a little more helping zooom to the old caps. If you don't mind to spend a little more, replace the main filter caps with new low ESR caps will give you a better improvement. Of course, you can do both :-)
Have fun!!
-fredv- -
If I could find replacement 10,000uf 100v caps in audio grade, I might entertain the thought of replacement. But I can't find a source for them!Ludicrous gibs!
EPCOS
http://www.alliedelec.com/Search/SearchResults.aspx?Ntt=10000uf+100v&Ntk=Primary&sid=11F8E16DDA28&i=9&Pst=10000uf+&N=0&sw=y"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Ooookay... I won't be spending more for the caps than I did for the amp just now. Maybe if it dies
Ludicrous gibs! -
Nelson Pass swears by computer grade Panasonic filter caps, have you looked into those? Many DIYer's use his suggestion for their projects."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Ditto, I am quite happy with Panny. Digikey:Nelson Pass swears by computer grade Panasonic filter caps, have you looked into those? Many DIYer's use his suggestion for their projects.
http://search.digikey.com/scripts/DkSearc/dksus.dll?Detail&name=P10038-ND
-fredv- -
Except I need to have screw terminals - http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=338-1265-ND which of course quadrupels the price.Ludicrous gibs! -
How about this?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=135652
Pretty good price. Of course, this is still almost 3X of the Dayton .... But imagine you still can hear the music for 1 min after you turn off the power :-)
-fredv- -
That's ME!!!! I have 5 555's in my HT rack now. The two from fredv have the mod. The other 3 soon will have it done. I just added the new cap to my CS350ls, now I'm opening up my Adcoms. Do it. The sound is noticeably improved. Thanks again FredCenter- (2) CS350ls
Mains - Rti12 Biamped
Sides - Fx1000
Rear - LSi/fx
Amps (5)Adcom GFA-555
