Info on shunt caps for Adcom GFA-545?
nadams
nadams Posts: 5,877
edited February 2009 in DIY, Mods & Tweaks
Can I do the shunt cap mod on my GFA-545? If so, what type of caps do I need? I'm very familiar with capacitors on computer motherboards, as I've replaced scores of bad ones. Audio caps, on the other hand, baffle me. :confused:
See here for pics of a 555 with shunt caps installed - http://www.polkaudio.com/forums/showthread.php?t=76378
Thanks in advance,
Noah
Ludicrous gibs!
Post edited by nadams on
  • ben62670
    ben62670 Posts: 15,969
    You can easily do the mod. All you need is some 100v or better film caps like you would use in an XO. Now what values you use are controversial. I like either 12uf, or a combo of 20uf, and 1uf paralleled. I will be doing this mod soon. I had a 555 with the mod. I take a look at the schematic to see if there are any input caps that should be replaced. Shoot me a PM if I don't post an answer by this evening.
    Ben
    Ben
  • nadams
    nadams Posts: 5,877
    So then, I'm looking for something like this, right? - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=027-430
    Would I need 2 or 4?
    Ludicrous gibs!
  • fredv
    fredv Posts: 923
    4, one by pass per main filer cap.
    I did this before I shipped my pair of GFA-555's the new happy owner.
    This is a low cost way to give a little more helping zooom to the old caps. If you don't mind to spend a little more, replace the main filter caps with new low ESR caps will give you a better improvement. Of course, you can do both :-)
    Have fun!!
    -fredv-
  • nadams
    nadams Posts: 5,877
    If I could find replacement 10,000uf 100v caps in audio grade, I might entertain the thought of replacement. But I can't find a source for them!
    Ludicrous gibs!
  • Face
    Face Posts: 14,340
    nadams wrote: »
    EPCOS
    http://www.alliedelec.com/Search/SearchResults.aspx?Ntt=10000uf+100v&Ntk=Primary&sid=11F8E16DDA28&i=9&Pst=10000uf+&N=0&sw=y
  • nadams
    nadams Posts: 5,877
    Ooookay... I won't be spending more for the caps than I did for the amp just now. Maybe if it dies :o
    Ludicrous gibs!
    heiney9 Posts: 25,630
    Nelson Pass swears by computer grade Panasonic filter caps, have you looked into those? Many DIYer's use his suggestion for their projects.
  • fredv
    fredv Posts: 923
    heiney9 wrote: »
    Ditto, I am quite happy with Panny. Digikey:
    http://search.digikey.com/scripts/DkSearc/dksus.dll?Detail&name=P10038-ND
    -fredv-
  • nadams
    nadams Posts: 5,877
    fredv wrote: »
    Except I need to have screw terminals - http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=338-1265-ND which of course quadrupels the price.
    Ludicrous gibs!
  • fredv
    fredv Posts: 923
    How about this?
    http://www.diyaudio.com/forums/showthread.php?s=&threadid=135652
    Pretty good price. Of course, this is still almost 3X of the Dayton .... But imagine you still can hear the music for 1 min after you turn off the power :-)
    -fredv-
  • rabies_70
    rabies_70 Posts: 47
    fredv wrote: »
    That's ME!!!! I have 5 555's in my HT rack now. The two from fredv have the mod. The other 3 soon will have it done. I just added the new cap to my CS350ls, now I'm opening up my Adcoms. Do it. The sound is noticeably improved. Thanks again Fred
    Center- (2) CS350ls
    Mains - Rti12 Biamped
    Sides - Fx1000
    Rear - LSi/fx
    Amps (5)Adcom GFA-555
