Anyone into Flight Sims?
RuSsMaN
Over the top, or just about right?
Cheers,
Russ
Cheers,
Russ
That is insane.....
Thats a wet Dream for Liv4famDan
holy.............................crap...................WOW! Talk about...........*vision*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That is pretty cool.
It would be good for pong. -
I have a setup that's remarkably similar to that one; the difference being that mine presents the user with a panoramic simulation of hard-core bestiality ... you're right in the middle of the herd and all bets are off! I can tell you that there's nothing like running down an Emu in your forevision, all the while keeping tabs on movements of some soon to be had Zebra's, 90 degrees to your right!
Heaven's, I hope that I haven't offended anyone; it's just that I'm new here and wanted to share my other passion (with audio being the obvious ). When I saw the attached picture, it reminded me so very much of my own setup. Peace.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
