not much bass from lsi 25
raidersrule76
Ok not sure what i might be doing wrong so someone please help. Just hooked up my new LSI 25:D and for some reason the bass is there just not like I had with my PSW 404 I assume that I should at the very least have the same amount of boom that I had unless im doing something wrong. I dont know it it has to do with the fact that im using a parasound A23 as an amp for them and im using my Yammy HTR 5790 as my pre for the time being. I do have a P3 pre but due to it being only 2 channel Im not using it so that I can still have my surround for my home theater. Any help would be helpful.
Thanks Mark
Thanks Mark
Sig to be updated after dealing with the insurance company:(:(:(
Post edited by raidersrule76 on
You may just be hearing BASS and not BOOM
There is a difference after all.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are they plugged in?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
$10 bucks says it's your source. Also, are the 25s set to Large?
yes they are plugged in im dumd just not that dumb.Sig to be updated after dealing with the insurance company:(:(:(
Oh and as far as being set to large yes they are. When you say its my source do you mean my avr or my amp?Sig to be updated after dealing with the insurance company:(:(:(
I mean where's the music coming from . . . cd player, PS3, 360, turntable, computer, iPod, tape deck, electric guitar, etc.
Vr3MxStyler2k3 wrote: »You may just be hearing BASS and not BOOM
x2 on that.
There is a break in period for your ears whenever you get new speakers...the issue may be that you're hearing cleaner bass, that doesn't necessarily have as much boom. This isn't a bad thing.;)
If it's really an issue, hook the PSW404 back up.
I have heard that the 25's are fairly complicated to set up, and require frequent adjustment due to the powered subs.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
SolidSqual wrote: »I mean where's the music coming from . . . cd player, PS3, 360, turntable, computer, iPod, tape deck, electric guitar, etc.
If it's an electric guitar...damn...bannable offense there.:pThe nirvana inducer-
comfortablycurt wrote: »If it's an electric guitar...damn...bannable offense there.:p
Yeah I know . . . just making sure that I don't have to make a PM to Justin. You never can tell with these new guys
SolidSqual wrote: »Yeah I know . . . just making sure that I don't have to make a PM to Justin.
Good call.The nirvana inducer-
So what's the source??? Just so you know, we're not making fun of you. Guitars kill home audio speakers and some morons don't seem to know that.
heck im used to being made fun of and do not take offense. The source would be a couple different things that I have tried first would be a cd via the BD player the other is an Ipod via the usb on the tv. Both are hooked up with a optical cable to the avr. Have not had a chance to watch a movie yet because the other half said that I had to keep it down for the night due to sick kids. Hopefully tommorrow they will go to school and I will be able to try a couple different movies and see what happens.Sig to be updated after dealing with the insurance company:(:(:(
You just got them today, right? It may be a simple case of the fact that new speakers need to break in before they start to perform properly.Political Correctness'.........defined
President of Club Polk -
Are they wired in phase?
Also check that the phase switch on the amp is in the same(normal)position on both speakers.
Aswell the bass level control may be set too low?Testing
Testing
Testing -
I think you have phase issue. You have three subs to integrate into your system and if one of them out of phase, you do not hear much bass.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1. -
im only running the two LSI 25's right now I do not plan on hooking up the PSW 404. So I would think that its not a phase issue, but maybe it still is.Sig to be updated after dealing with the insurance company:(:(:(
raidersrule76 wrote: »im only running the two LSI 25's right now I do not plan on hooking up the PSW 404. So I would think that its not a phase issue, but maybe it still is.
Yes, you still have the phase issue when you run Lsi25s only. Try to play with the phase switch on Lsi25s you will have better result.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
It can also be a placement issue. Moving them around and see if things improve."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
try taking off the jumpers and hooking the subs up to the amp pre outTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
ok guys I really thank all of you for your advice. Been messing around with settings and what not for bout a hour or so today and I think that I have it figured out sounds much better. Thanks again will let everyone know how much I enjoy these after I get some more use out of them.Sig to be updated after dealing with the insurance company:(:(:(
Well, what did you do?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I would add amplification...LSI 15
LSI C
LSI FX
80 fx ls for atmos
Velodyne SPL-10
Marantz 7012
Panasonic 9000
JVC 420 -
Well the first thing that I tried was hooked my mic for the Htr 5790 and let it go through the set up. After that I messed with the volume controls on the back of the Lsi's and that helped a little bit. After I did that I put on a movie and holy crap yea much better then the music sources that I was listening too so maybe that had something to do with it too. And as far as an amp I am running a Parasound Halo A23 so I would think that is enough power to run them.Sig to be updated after dealing with the insurance company:(:(:(
raidersrule76 wrote: »Well the first thing that I tried was hooked my mic for the Htr 5790 and let it go through the set up. After that I messed with the volume controls on the back of the Lsi's and that helped a little bit. After I did that I put on a movie and holy crap yea much better then the music sources that I was listening too so maybe that had something to do with it too. And as far as an amp I am running a Parasound Halo A23 so I would think that is enough power to run them.
I used to use the A23 with my 15s and they're a harder load to drive than the 25s since they are not powered. The results were great. You are not hurting for amplification . . . unless, how bigs your room and where are the speakers placed?
The difference in sound between movies and music still makes me think it's your source. Do you happen to own an old Xbox or new one? Both those systems play music and tend to increase the bass. If you can, try that . . . or use an alternative CD player. -
Do you hear that buzzing noise?
