Monoblock vs. Bi-Amp
LarryK
After a second thought, this post might be better in this forum... At the risk of being shot for even using the word "Bi-Amp" I have a question (or two). We are working off a clean sheet of paper so all options are open. I have LSi15's, LSiC, PSW10 Sub & LSi7's (which I am going to replace with LSiF/X. I have an underpowered receiver so it's seperates time.
I am thinking of going the monoblock route for fronts and 3, 5 or 7 channel amp for the rest. Would there be any advantage to Bi-Amping this as well (I would also get an active crossover)? From what I've read here, it's pointless to Bi-Wire. Is the internal crossover knocked out automatically when the external x-over is used or do you need to do some surgery to the speaker? Is it worth it? Finally, what is the difference between Bi-Wire and Bi-Amp speaker cable?
Thinking of new Emo's (I know, enough of that too) vs. used Mac. Your thoughts are much appreciated... be kind as I am somewhat new
Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Surround: Polk LSiF/X
Sub: Polk PSW10
Amps: Rotel RB 993 &
Parasound HCA-800 II
Pre/Pro:Anthem AVM-20
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Post edited by LarryK on
You've got MANY options on amps; any idea which direction you want to head to narrow it down a little?
The BEST way to bi-amp is to actively crossover before the power amp stage & remove the internal passive speaker crossover. However, there are a lot of things taken into account in the speaker crossover like in/out of phase changes that occurr & peaks/dips in the speaker, to name a couple. It's still advantageous, though slightly less so, to leave the internal crossover in place while actively bi-amping. The main advantage in this arrangement is more available power/headroom & less strain on each individual amp.
Bi-wire -vs- bi-amp cables: bi-wire cabling will many times be the SAME circuit, larger in diameter. You CANNOT bi-amp with a bi-wire cable of this type. They have to be completely separate in order to bi-wire. Personally, I think bi-wiring is a complete waste of time except in certain extreme circumstances (for example, if the only available cable was of an extremeley small gauge & you doubled it up to increase throughput/decrease resistance).TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Great Info! Thinking of MC501's vs. Emo XPA-1's, MC205 vs. Emo XPA-5, and for proc MX120 vs. new EMO when it arrives. I know even at used prices the MAC's are going to be $$ higher, worth it?? a another question for another post.
Do I also get the feeling from what you have said, if you don't know what you are doing, don't touch anything?? Thanks again.Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Pre/Pro:Anthem AVM-20 -
Keep it simple. Forget about monoblocks for HT. Just buy an XPA-5 and be done with it. And forget about replacing the Lsi7's. If you want something else to do, get a bigger, better subwoofer.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
+1
Get a good 5 channel and be done with it. Also get a better sub. -
I have never heard an Emo so can't comment there. If you go with McIntosh, you're not only buying good gear, you have a company behind you that has been in the business since the 40's. If you have the coin to drop on the McIntosh, I think it would be worth it, but I am biased
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Agreed. When I had my HT and switched to a 7 channel amp from separates, it saved me so many hassles and headaches, not to mention space. Just get one big amp and be done with it. -
Agreed
Exactly,If it is not done properly the end result may well sound substantially worse than the stock passively crossed over version.However, there are a lot of things taken into account in the speaker crossover like in/out of phase changes that occurr & peaks/dips in the speaker, to name a couple.
I disagree with this point.Cascading an active xover with the stock passive unit will run the same risk as mentioned above about using the active xover alone.It must be designed to work with the particular system or the results will be less than satisfactory.It's still advantageous, though slightly less so, to leave the internal crossover in place while actively bi-amping.
Yes when an active setup is properly implemented.The main advantage in this arrangement is more available power/headroom & less strain on each individual amp.Testing
Testing
Testing -
Thanks to all, great information and another view(s) to look at as I go forward. This helps alot!!Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
