Monoblock vs. Bi-Amp
LarryK
After a second thought, this post might be better in this forum... At the risk of being shot for even using the word "Bi-Amp" I have a question (or two). We are working off a clean sheet of paper so all options are open. I have LSi15's, LSiC, PSW10 Sub & LSi7's (which I am going to replace with LSiF/X. I have an underpowered receiver so it's seperates time.
I am thinking of going the monoblock route for fronts and 3, 5 or 7 channel amp for the rest. Would there be any advantage to Bi-Amping this as well (I would also get an active crossover)? From what I've read here, it's pointless to Bi-Wire. Is the internal crossover knocked out automatically when the external x-over is used or do you need to do some surgery to the speaker? Is it worth it? Finally, what is the difference between Bi-Wire and Bi-Amp speaker cable?
Thinking of new Emo's (I know, enough of that too) vs. used Mac. Your thoughts are much appreciated... be kind as I am somewhat new
Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Surround: Polk LSiF/X
Sub: Polk PSW10
Amps: Rotel RB 993 &
Parasound HCA-800 II
Pre/Pro:Anthem AVM-20
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Post edited by LarryK on
You've got MANY options on amps; any idea which direction you want to head to narrow it down a little?
The BEST way to bi-amp is to actively crossover before the power amp stage & remove the internal passive speaker crossover. However, there are a lot of things taken into account in the speaker crossover like in/out of phase changes that occurr & peaks/dips in the speaker, to name a couple. It's still advantageous, though slightly less so, to leave the internal crossover in place while actively bi-amping. The main advantage in this arrangement is more available power/headroom & less strain on each individual amp.
Bi-wire -vs- bi-amp cables: bi-wire cabling will many times be the SAME circuit, larger in diameter. You CANNOT bi-amp with a bi-wire cable of this type. They have to be completely separate in order to bi-wire. Personally, I think bi-wiring is a complete waste of time except in certain extreme circumstances (for example, if the only available cable was of an extremeley small gauge & you doubled it up to increase throughput/decrease resistance).TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Great Info! Thinking of MC501's vs. Emo XPA-1's, MC205 vs. Emo XPA-5, and for proc MX120 vs. new EMO when it arrives. I know even at used prices the MAC's are going to be $$ higher, worth it?? a another question for another post.
Do I also get the feeling from what you have said, if you don't know what you are doing, don't touch anything?? Thanks again.Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Pre/Pro:Anthem AVM-20 -
Keep it simple. Forget about monoblocks for HT. Just buy an XPA-5 and be done with it. And forget about replacing the Lsi7's. If you want something else to do, get a bigger, better subwoofer.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
+1
Get a good 5 channel and be done with it. Also get a better sub. -
I have never heard an Emo so can't comment there. If you go with McIntosh, you're not only buying good gear, you have a company behind you that has been in the business since the 40's. If you have the coin to drop on the McIntosh, I think it would be worth it, but I am biased
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Agreed. When I had my HT and switched to a 7 channel amp from separates, it saved me so many hassles and headaches, not to mention space. Just get one big amp and be done with it. -
The BEST way to bi-amp is to actively crossover before the power amp stage & remove the internal passive speaker crossover.However, there are a lot of things taken into account in the speaker crossover like in/out of phase changes that occurr & peaks/dips in the speaker, to name a couple.It's still advantageous, though slightly less so, to leave the internal crossover in place while actively bi-amping.The main advantage in this arrangement is more available power/headroom & less strain on each individual amp.Testing
Testing
Testing -
Thanks to all, great information and another view(s) to look at as I go forward. This helps alot!!Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
