hooking up an amp
RJaco
I have a Yamaha 6140 avr. It doesn't have a place to hook up an amp. But on the front there is a place that says portable. It accepts a 3.5 mm. I remember reading something about hooking up an amp kind of like this. Something about plugging in the cable and if the speakers play, then an amp would work. Not sure if I want to do this, but just wondering if it would work. I have the cable and plugged it in already. The speakers still play.
Post edited by RJaco on
Preamp outputs are what you are looking for.
Looking at the owner manual for your AVR you do not have pre-outs.Speakers: SDA-1C (most all the goodies)
You are referring to the headphone output. It will work to power an amp, but the signal may become distorted when driven hard. Too many amplified sections working in the chain for great sound.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks. I wasn't planning on using an amp but just wondering if it would work.
