Experience with LONG balanced IC's??
Ricardo
I am already using balanced IC's everywhere; I want to move my rack to a side of the room, just leaving a small stand with the amp between the speakers and the front wall. This would require using approx. 15 ft IC's.
Has anyone done this and confirmed that there's no sound degradation? I know that in theory this would not be a problem using balanced, but they would not be cheap and would like to hear from someone that had some experience.
SOPA
SOPA
Post edited by Ricardo on
It all depends entirely on your equipment, setup, and any noise sources. Many folks can run unbalanced that distance with no issues, while others must used balanced to avoid spurious noise from multiple sources. The only way to know for sure is to try it.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I ran 5 14' unbalanced cables from a pre/pro to a amp rack and never experienced any issues."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I think I'm going to go for it. Thanks guys!_________________________________________________
Longest balanced run I have is 10'. No issues with noise or artifacts that I can detect in my 2ch setupWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
When I went to the Toby Keith concert they were runing balenced signals over 150'
Don't worry with good cables.
Ben -
Balanced are made for long runs. I've done pro jobs with 100-200 foot runs with snakes that have 24 gauge pairs in them.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yep, the advantage of the differential signal and full separate shield is immunity to noise.Dennis Gardner wrote: »Balanced are made for long runs.Testing
Testing
Testing -
Same here. I switched some equipment around on my last set-up (ATI 5-channel amp, Sony ES pre/pro) and moved the amp to a rack about 15 feet out. Absolutely no change whatsoever (and they were basic Esoteric IC's - nothing special).Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
