what gauge wire for 35 ft run.
Flash!
My amp will be about 35 ft. from my lsi9's. Do you think 12 gauge would be sufficient? I am using a Carver tfm42 amp.
Post edited by Flash! on
i use monoprice 14awg, works for me, bout the same distance.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
great. thanks for the info.
http://www.roger-russell.com/wire/wire.htm
page down a few times and you'll see a great chart of what to use.PSN: BigNig -
The next time I see roger-russell I am going to club a baby seal:rolleyes:
Use 12ga for LSI's at that lenght.
Ben -
12 gauge is more then plenty especially at that length. 35 feet is not a long run.Dan
Ok! 12 gauge it is. Thank you guys for the info.
