Anybody ever hear of iceblock?
nooshinjohn
I found these while cruising the web...
http://store.audioholics.com/product/1949/66225/seymour-av-500w-x-1-ice-block-amplifier--silver-115v-
Does anybody have a clue about them? Are they affiliated with B&O as it tends to have me believe...
They look really cool
Post edited by nooshinjohn on
Nothing new here,like dozens of other companies they source the ASP ICEPower modules from B&O and put them in a custom chassis and charge big bucks.Testing
Testing
Testing -
Agreed, go to D-Sonic, different chasis, less bucks, awesome amps.Shoot the jumper.....................BALLIN.............!!!!!
nooshinjohn wrote: »I found these while cruising the web...
those have the 500ASP ICEmodules in them...500W/4ohm
they charge an arm and a leg for a sheet metal case and a blue LED light...
you can get a 1000ASP - 1000W/4ohm for $450...and add some high end connectors for much less than above
http://www.marchandelec.com/pricelst.html
or go d-sonic amps for the best deal if you dont want to diymy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
+1
they are assembled in a ISO9001 certified shop and are built like a tank
my 7.(1x4) HT setup
Buttkicker
