Better to wire to receiver or t.v. first?
poloman1211
poloman1211 Posts: 28
i ask this question because, i know wanted to know if there is a performance difference if i wire my (ps3, cable, dvd. etc) to the tv first, then the sound out from my tv to my recevier. I wanted to wire this way because sometimes i just want to watch tv by itself without the rec/speakers on all the time. will i be losing sound quailty?
thanks
Post edited by poloman1211 on
  • Solumnus
    Solumnus Posts: 48
    edited February 2009
    You would be, unless your TV has digital audio in and out. Or an HDMI Out.
    You need an audio digital coax, audio fiber optic (toslink) or HDMI cable going into the reciever to get any digital surround sound from PS3, HD cable, DVD, etc.
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
  • comfortablycurt
    comfortablycurt Posts: 6,745
    There's typically a significant loss in audio signal from a TV's audio out's. You'd be better off going to the receiver first.
    Most receivers have a setting specifically for TV watching that mainly uses the center channel. Have you tried that at all?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • poloman1211
    Solumnus wrote: »
    my tv does have a fiber optic out, so will it be the same as going straight thur the recevier
    still new to the ht. i only have fronts and no center. just seems like i dont need big speakers all the time to watch regular tv.
    thanks
  • SEH
    SEH Posts: 91
    No. Most TVs are not made to be audio switchers or audio processors. The optical out is to get Dolby signals received through the antenna to your receiver where they can be processed, since your TV probably has no Dolby decoder. Your components are going to have to output stereo to your TV, and stereo (at best) is all you'll get out of your TV.
  • rengnath
    rengnath Posts: 118
    I used to have the same issue with wanting to watch tv with no stereo. I settled with just being able to watch cable by itself with no stereo, and then run everything else with the receiver. I plugged the cable box to the wall, then used component video and the optical out from the box to run into the reciever. Next, I ran the coax video out from the cable box into the tv. I dont know if you tv has a coax in, but I know when I had a tube tv it did. Also, your cable box would have to be able to support two video outs at the same time. This would allow you to just change you video input on the tv when you wanted to just watch cable by itself, or change the video input on the tv to watch whatever through the reciever. Now, I fell so in love with my stereo that I cant watch tv without it. Hope this helps.
    AVR - Yamaha Aventage RX-A800
    Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
    Mains - RT1000i Towers
    Center - CS400i
    Sub - BIC Acoustech PL200
    My neighbors listen to very good music, whether they like it or not :cheesygrin:
  • Mike21
    Mike21 Posts: 252
    I always use my surround system for TV: all channel stereo for news, talk shows, game shows; 5.1 or 7.1 for everything else (movies, 24, the CSIs, House, NCIS, Criminal Minds, Grammys,etc ).
    Mike21
    _______________________________________________________________
    32" LG LCD
    Comcast Cable
    Toshiba A-2 HD-DVD player
    Samsung 1500 Blu Ray Disc player
    Sony NS999ES DVD/SACD/CD player
    Onkyo 805 avr
    Fronts: Polk M50s
    Center: Polk CS2
    Sides: Polk m40s
    Rear: B&W LM1s
    Sunfire True Subwoofer (the origianl model)
    Audience Au24 speaker wire (front 3)
    Transparent Link 100s - interconnects
    Belkin HDMIs
    PS Audio Punch power chords (12 gauge)
    PS Audio Duet, Ultimate Outlet and Noise Harvestors
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • rayslifecycle
    rayslifecycle Posts: 511
    I understand your predicatment.......and there fore I recommend the following hookup:
    Wire all components to your receiver using digital connections as described earlier in this thread. All audio and video is switched with the Receiver. This will give you the best quality when you want it.
    Afterwards - run the standard coaxial cable-wire from your cable box to your tv. That connection will enable you to use your TV/cable as a standalone system....
  • poloman1211
    SEH wrote: »
    so why doe the tv have fiber optic out for ?
  • SEH
    SEH Posts: 91
    If you use the antenna and built-in tuner to get TV broadcasts with Dolby audio, you have to have some way to get that to a receiver.
  • avhomedesigns
    avhomedesigns Posts: 29
    Always connect to the receiver first...
