Beasties Remastered
phipiper10
Not sure if this has been mentioned but....It's the 20th Anniversary of Paul's Boutique. Even something your you vinyl guys here
http://paulsboutique.beastieboys.com/purchase/index.html
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
Oh hell yes I'm getting the vinyl when it comes out. That album is a masterpiece, but the original releases sounded a bit thin. I've heard the remaster sounds much better. Can't wait!Wristwatch--->Crisco
Just ordered mine. Lossless download in process, warm'n up the TT for when the vinyl gets here.(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
Transparent SoundWave Super
Paradigm Studio Monitor
B&W 802 s3
HT
Sony Bravia KDL-40Z4100
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12 -
So how does it compared to the original CD?
After hearing The Mix Up, I'm betting this is going to be killer. I'm cynical though considering recent other 'remasters' that @#$%ed up the original more than fixed it. -
The vinyl doesn't come out 'till tomorrow, but I've read positive comments about the SQ of the cd remasters.
If it sounds as good as The Mix Up does I'll be quite content.
I'm going to memorize the track by track album commentary the Beastie Boys did for this so I can impress people at parties and happy hours.Wristwatch--->Crisco -
If you are at a party don't talk ....just..... Shake your Rump!!!!!!!!!!!!!!!!!!!!!!!!!!Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Haven't had a chance to do any "critical" listening but the new mastering is definitely louder. Can't make any statements as to SQ as i've only done a side by side on my computer speakers.(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12 -
So any impressions from those who have listened to the remastered CD yet?
I love the original album, but as someone mentioned above it does sound thin...not a particularly good recording. Just want to see if they got this one right before I buy it again.2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
