Boost for mp3 signal?
djseafood
I was wondering if there is such a device that would boos the signal on the output of an mp3 player (like an iPod/whatever) so that it will play louder through my AVR? Currently, using the mini-jack to RCA cable, my mp3 player does not get very loud even with the volume on the mp3 and AVR all the way up. (don't worry, I only did this for a split second to see if it had any affect). I like the versatility of hooking up the mp3 player to my system but it just doesn't get loud enough to make it worth it.
Thanks for any help!
HT
Receiver: Onkyo TX-SR506
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
Patio: Polk Atrium 45
TV: Sony Bravia KDL-46XBR9
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
Receiver: h/k AVR 20
CD: marantz Professional PMD320
Mains: Infinity SS2005
2nds: DLK 1 1/2's
CNTR: Infinity Sterling Video
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
Post edited by djseafood on
digital connections are much louder. Try finding some kind of dock with digital outputs. I use my appleTV and it works awesome for being able to stream all my itunes music in applelosslessPro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands -
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
SACD huh? That's helpful.
By the way, I checked out your youtube video of your SDA's and they sounded pretty buzzy. You might want to fix that.... (just messing with you by the way)HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp. -
A dock with a line out will be louder than the minijack, but really the analog output on anything intended to be used with headphones is weak. There are liability issues if you sell a product that makes the customers go deaf.
Thanks bigred7078 and SEH. Guess I'll try to find a good dock. That makes a lot of sense about the liability issue too.HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
