Newby looking for some guidance
TheLloyds
TheLloyds Posts: 4
edited February 2009 in The Clubhouse
I am putting together a family oriented 7.1 system and would like some guidance. So far I have Monitor 70’s in the front, Monitor 50’s for the sides, CS2 center and 404 sub. Now I need to look toward the rear and receiver. Right now I am thinking either Monitor 40 or moving the 50 back and getting some 60’s in their place. The receiver I am looking at is the Onkyo 806. The system will be used in a family room for movies, tv and wii. Am I on the right path or is their another direction I should consider
Post edited by TheLloyds on
  • nadams
    nadams Posts: 5,877
    What are the room dimensions? This will effect the power requirements from your receiver, and the size requirements for your rear speakers.
    Ludicrous gibs!
    nooshinjohn Posts: 26,001
    perhaps another pair of 50s in back?
  • TheLloyds
    TheLloyds Posts: 4
    nadams wrote: »
    It’s a very long room 41 feet by 16 feet. 24 ft. is family room the rest is dinning room, I am only concerned with filling the family room space but I know it’s doesn’t work that way. It is also a vaulted ceiling 8ft on the low side (on the left when you are looking toward the TV) the right side is 11ft. It is 14 ft. from the M70’s to the prime seating area. Thanks for your time.
  • schwarcw
    schwarcw Posts: 7,358
    Greetings and welcome to the Club Polk Forums! There is a lot of good material on this website. Check out the following link, start at page 29. Look Here
    You'll find a lot of info by Googling "HT Room Setup", lot's of info about large size room, etc. Simplest rule of thumb is that you want to have a rectangular orientation, long walls in front, at least 3 to 4 feet from the side wall on the short side. Front speakers should be an equilateral triangle from your front listening position. Front speakers should have tweeters at ear level, surround speakers should be dipoles about six feet from the floor. I like front and rear subs, one rear center, get an SPL meter to balance it all.
    Do your research and ask some questions. Don't cheat yourself on power. The more power the better. Notice that I didn't say louder. More watts will get you better detail and improved sound stage. Room treatments are also a plus, some simple placement of sound absorbing material, or geometric interferences that break up reflections, large plants, curtains or drapes, even a coat rack with coats can do some good to knock down the reflections that can overload a room and muddle the image.
    Good luck!
    Carl
  • TheLloyds
    TheLloyds Posts: 4
    Thanks Carl, I will check it out.
  • TheLloyds
    TheLloyds Posts: 4
    Thank you for your help, I went with the Onkyo 806 and it has made a big diff. over my old 520. As for rear sound I am stiking with the 5.1 system for now and bi amping the m70's. Onkyo's auto calibration set up worked out nice.
