Hot yamaha receiver and Rotel amp
Hobbyguy
Hobbyguy Posts: 317
edited February 2009 in 2 Channel Audio
Does anybody know how hot a yamaha receiver and Rotel RMB 1095 run?
I checked th surface temp with my infrared thermometer and it reads 130 F.
Richard
Post edited by Hobbyguy on
    heiney9 Posts: 25,445
    Not sure I understand your question :confused:. Which one, both separately, together, while playing loud, while idling, etc, etc? What speakers are you trying to run, how many?
    Which Yammy? Location in a cabinet?
    The Rotel should run hotter than the Yammy by design, cooling it *may* hurt the sound as it's an A/B amp with a slight bias into class A. Cooling the tranny's won't allow them to reach the proper operating temp for the best sound.
    External cooling should only be used if the amp is running beyond it's rated temp. The Rotel should have thermal cut off if it gets overly hot.
    As far as the Yammy (and receivers in general) they tend to skimp on heat sinks partly because of space and because of cost cutting. So the Yammy might be running hot because of a design limitation.
    We need more info
    P.s. my single ended class A amp will run so hot you can't touch the heat sinks for more than a couple seconds.........is that wrong...........nope that's how it's designed to run and the parts are chosen accordingly to ensure long life.
    nooshinjohn Posts: 25,931
    yami should never run that hot, and as far as rotel i have no clue... one thing missed in the assesments above is do you have them stacked on to of each other?
    I am willing to bet that you have the yamaha sitting directly on top of the rotel. if so this would be the cause of the trouble. amps should never be stackes on top of each other...
  • Hobbyguy
    Hobbyguy Posts: 317
    Thanks for the above advice. I have an old vertical cabinet with front glass, there are 4 shelves. The rotel is on the bottom shelf, the yamaha RX-v2700 is above this on its own shelf and there is about 3 inches above the top of each component. At idle they are both hot. I keep the front glass closed but the back is open. The top of the case of the yamaha gets so hot that it is uncomfortable to touch....this is where I have been aiming the lasers from my IR thermometer. Neither amp has shut down even during moderate volume (just pushing 2 SDA-1Bs) but the heat is alot more than when I just had the yamaha alone.
  • megasat16
    megasat16 Posts: 3,521
    I own a Rotel RMB-1095 all in Black Color and this amp has a tendency to run HOT. It's normal and it'll go into protected mode when it thinks it is too hot (it's kind of like u can fry an egg on it). Mine goes into protected in about 10 minutes if I put it on a carpet floor because of no ventilation or air flow around it. When I put it on the small wooden cart with wheels in wide open space, it runs a lot cooler and plays all day long and sounds good. I also have Yammy RX-V1700 for HT and it is also very Hot and it's normal.
    Run both of these with as much as ventilation as possible for their long life reliability. If you put them in the case, it's a wise idea to open both the front and the back when using them.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Motzart
    Motzart Posts: 1,075
    I crank up my Yammy now and then and it don't get hot just lil warm.
    But I have it in a open stand and plenty of space tween shelves.
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • fossy
    fossy Posts: 1,378
    Try it with the door open & see what the temp's are. You might need a little fan if they are still running hot.
    Yamahas do not run that hot. Onkyos are notorious for 128-145 temps on some units!
    Don't know about the Rotels...I assume they run a bit hot. Mike21 uses a small fan to cool his Onkyo...it brings those temps way down!
    cnh
