Eliminating scratches on the piano black finish
ViperZ
ViperZ Posts: 2,046
edited February 2009 in DIY, Mods & Tweaks
I have some fine, but long scratches on the piano black finish on one of my speakers. I don't think any of the scratches are deep and go through the paint/finish.
What can I do to eliminate those scratches? Any advice on the buffing material?
Thanks!
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
Post edited by ViperZ on
  • NJPOLKER
    NJPOLKER Posts: 3,474
    I bet the President-F1nut will have an excellent recommendation for you.
  • thsmith
    thsmith Posts: 6,082
    If you drag your finger nail across it do you feel the scratch, if yes then the paint is broken.
    I suggest safe-cut to remove scratches that are not into the paint.
  • ViperZ
    ViperZ Posts: 2,046
    Fortunately, it's all good and flat, so just scratches on the finish... What's 'safe-cut'?
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • ViperZ
    ViperZ Posts: 2,046
    NJPOLKER wrote: »
    Found F1Nut on the Carver forums ;). Will try Scratch-X in the next few days.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    F1nut Posts: 51,764
    Yes, oddly enough as I'm here more than there.
  • mmadden28
    mmadden28 Posts: 4,283
    Kex wrote: »
    You're also bad ... and ... you're nationwide. I have it from highly trustworthy sources. That's gotta count for something.
    Hate piano finish now BTW. Too much trouble if kids can reach it: things just always seem to happen (mmadden, take note!).
    :D
    Staying away from Daddy's audio stuff is a high priority in my boys early training. ;) Of course that didn't stop them from taking the grill from my RTi12 and using it as a ramp to climb onto the chair thus breaking it into 3 pieces. No it didn't. :eek::mad::mad:
    Time for some tough love. So far, they've kept thier sticky fingers away from the shiny uPro4k :cool:
    I don't care for the Piano Gloss either--seems to be a dust magnet too.
    ____________________
    Pool: Atrium 60's/45's
  • leroyjr1
    leroyjr1 Posts: 8,785
    mmadden28 wrote: »
    :D
    The high gloss on the mp4k seems a lot more durable than my lsi9's
