Deoxit
Toolfan66
Toolfan66 Posts: 17,336
edited April 2010 in Vintage Speakers
What Deoxit should I get for my speaker terminals? I found the spray but can I just spray it on a piece of cloth and wipe the terminals on my drivers so I don't get the over spray on them? never used it so I am not sure what to get.
Thanks!!!
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
Post edited by Toolfan66 on
  • Conradicles
    Conradicles Posts: 6,134
    edited April 2010
    Larry not sure if this thread will help or not but here you go:
    http://www.polkaudio.com/forums/showthread.php?t=94496
    I need some more. You can never have too much of that stuff around!
    billbillw Posts: 6,863
    edited April 2010
    I wouldn't buy any DeOxit specifically for what you are talking about. I would buy the D5 flushing spray (for cleaning pots/switches) and use it for everything else too. I use it primarily to clean out scratchy switches and pots on vintage gear, but I also use it to clean RCA outputs, speaker terminals, etc.
    For cleaning connections, I use a couple different sized mascara brushes that my wife wasn't using anymore. Just spray a tiny bit on the connection, then brush. Keep a paper towel near to contain overspray/drippage. The D5 cleans off oxidation, but if you want to maintain, you also need to use the CAIG Pro Gold (or whatever its called today). You can get it in a brush on or pen style. Just apply and leave it.
    For rig details, see my profile. Nothing here anymore...
  • Knucklehead
    Knucklehead Posts: 3,602
    edited April 2010
    Thanks!!!
    To me this would be ok..or, you can spray a little into a cup and dip your terminals, thats what I did, no problems at all.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    edited April 2010
    Thanks good info guys!!! it's what I needed.
    SVS SB16 X2
  • headrott
    headrott Posts: 5,496
    edited April 2010
    I have used the Deoxit Gold, but I put the Deoxit Shield on my speaker terminals. See the link below. Either would work OK though (Gold or shield).
    http://store.caig.com/s.nl/it.A/id.2433/.f?sc=2&category=192
    Greg
  • Face
    Face Posts: 14,340
    edited April 2010
    Regular Dexoit in the nail polish container. Not a fan of the gold since it leaves a residue. And the fader lube(D5) is just for that, volume pots, etc...
  • skrol
    skrol Posts: 3,393
    edited April 2010
    Where would you use the 5% (D5) vs the 100% (D100) solution?
    Stan
    Main 2ch:
    HT:
    Other stuff:
    edited April 2010
    Face wrote: »
    D5 is not the same as fader lube. Fader lube is F5 (or other F designations). D5 is regular deoxit in a 5% flushing spray. It leaves no significant residue. Its designed to flush out dust and oxidation.
    Fader lube is just that, a lubricant designed to keep sliders/pots/etc in top performing condition.
    You might use it on an area where you do not want overspray or you don't need to flush. Just straight removal of oxidation. Personally, I make due with just the D5 stuff. I have a pen of the ProGold, but I normally forget to use it. Overall, the D5 is the most versatile of all Caig products IMHO.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    You can get DeOxit pretreated cloth wipes and use a wooden Q-tip to get into those tight spaces to wipe down the terminals and clean the banana insert hole.
