Thoughts on this speaker?
Pycroft
Pycroft Posts: 1,961
edited April 2010 in Speakers
http://cgi.ebay.com/Artistic-Audio-Moebius-Audiophile-Speakers_W0QQitemZ150432411608QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item2306786fd8
All looks? This is right price for me, and local. Looking for something with a full sound w/o subwoofer. Seems a little weak power wise -250 watts max. Room is 24x20 - gear is below in my sig. Would love ot hear thoughts. Are these all for looks, and not sound?
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • Dabutcher
    Dabutcher Posts: 2,606
    edited April 2010
    Look awesome. Never heard of them. Personally I would not send that much money to someone with 20 feedback. I guess there is paypal 's buyer protection? Good luck,Darryl
  • Pycroft
    edited April 2010
    I would pick up locally with cash, and ask to look and listen beforehand. Anyone else actually heard of these, or heard them?
    Thanks,
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    Tony M Posts: 11,826
    edited April 2010
    Those look like a pick-up type of speaker since they're 55 lbs. each. They do look cool as can be and worth it to me if they sound good. How many can be proud owners of speakers like those works of ART.
    Maybe see if you can speak directly with him/her and get a feel if you want to continue with the thought of buying them from him/her since the sales record is low.
    edited April 2010
    Put some arms on those and you've got two pretty good looking ROBOTS! lol
    cnh
  • Pycroft
    edited April 2010
    Here is some more information on these speakers. http://www.hometheaterhifi.com/volume_10_3/artistic-audio-mobius-speakers-9-2003.html
    Apparently they are getting rave reviews. Large soundstage, great imaging, etc. I'm guessing the omni-directional effect allows for the large sweet spot - trying to get it to have everywhere in the room be a sweet spot. Everything I've read about these is VERY favorable. Any further comments about these, or even about any speaker SIMILAR in structure as these (Omni directional)?
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    heiney9 Posts: 25,549
    edited April 2010
    Many omni-directional types lack a solid center image like conventional speakers. If you are used to a rock solid center image and other cues within the soundstage then omni's may not be for you. Omni's allow for better off axis sound, but lack precise imaging. It's a trade off. For me personally I always listen in the sweetspot and omni's just didn't do it for me.
    They also tend to loose depth within the soundstage, not that the image is flat...........just more diffused or cicular..........if you get waht I'm saying. Sort of like some sounds come out of nowhere, etc. Not like SDA's whihc has a very anchored center and front stage but then certain sounds seem to come from nowhere............Omni's are different than SDA's. SOrt of a "wall of sound" if I'm getting my point across.
    If you can get your ears on them. You may like them.
  • Pycroft
    edited April 2010
    In your experience, are they picky with placemetn. Looking at them, it almost seems like they should be in the middle of the room, with the sound moving throught the entire room from a central focal point. How do they work near walls? Ever experience an echo type effect, cause that would annoy the hell out of me. Also, these are rated at 250 wpc max at 8 ohms. Just seem not very powerful. Comments?
    Thanks for the info!
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • jojomgee
    jojomgee Posts: 198
    edited April 2010
    never heard of ...........wouldnt buy
    edited April 2010
    If you like that kind of sound,I would say try for some used Def Tech's. They come up on craigslist and Audiogon alot.
