New theater set up
jaybird_95
jaybird_95 Posts: 2
Hi all, I'm new here and was looking for some help. I am finishing my basement and thought it would be nice to do a home theater. My cousin gave me a RM 7500 set of speaker for it. I would like to put all of the wires in prior to finishing the sheet rock. Can anyone tell me what I should use. I plan on using a projector for the theater. I am also looking for a suggestion for what type of receiver I should use? any help is greatly appreciated.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    Hey jaybird, welcome to Club Polk. A few answers for ya regarding the speaker wire. There is a link below to Monoprice for all their speaker wires, and anything rated CL2 is what you need for in-wall installation. They have lots to chose from, but I would recommend 12 or 14AWG. The RM7500 is a pretty good HTIB and is pretty easy to drive so as far as AVR's are concerned look into Onkyo, Denon, HK, Pioneer, just to name a few. You don't nee any top of the line flagship models, but keep in mind you may outgrow the 7500 and want floorstanders soon enough, so get something that is fairly "future proof" As for Onkyo's look into the TX SR7XX series or higher, since they will have pre outs for adding an external amp down the road. Not something you will need with the 7500, but like I said, if you do decide to upgrade, it will be one less thing you have to get. Hope this helps, and good luck.
    -Jeff
    http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited April 2010
    WELCOME TO CLUB POLK!
    Jeff has you covered above...
    cnh
  • wutadumsn23
    edited April 2010
    Lol, thanks C. Took that post right out of a page from your playbook, lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • jaybird_95
    jaybird_95 Posts: 2
    edited April 2010
    Thanks, for the advise. what should I use for the sub? Is regular speaker wire good, or should i use a "monster" cable?
  • wutadumsn23
    edited April 2010
    The "M" word will start many a "discussions" around here, lol. Just get a subwoofer cable from the same website I recommended for the speaker wire, I would recommend getting a pretty long one so you can move the sub around and find the best spot in the room for it. I have a 25 footer, and it was well worth the extra few bucks for the added length.
    -Jeff
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2683&seq=1&format=2 This one is a good one and is just over $6 for a 25 footer
    http://www.monoprice.com/products/search.asp?keyword=subwoofer+cable Here is a list of them all
    HT Rig
    Blu-Ray- 80 GB PS3
  • cheddar
    cheddar Posts: 2,390
    edited April 2010
    Whatever you do, you might want to over wire yourself now so you don't have to open up the sheet rock again later. If deciding between 14 and 12 AWG, go 12. Maybe look into hdmi 1.4 cable etc. Run an in wall subwoofer cable (or even two sets, maybe you'll want more than one :)) to wherever you might want to place it if far from your rig (especially if you're putting your gear in an equipment closet).
    Monoprice cables won't break the bank and you don't want a situation where you upgrade your speakers and electronics at some point and find your cables are the weakest link.
  • wutadumsn23
    edited April 2010
    cheddar wrote: »
    +1, better to be safe than sorry with in wall installations. They can be kinda tricky to "adjust" lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
