Help with ohms
cnoat
cnoat Posts: 315
edited April 2010 in Speakers
Hello all
If I biamp my rti 12's does it make the highs and lows 4 ohms.I have a chance at a really good deal on an adcom 5400.I was going to use the amp for the lows and my avr for the tweet.Any feedback would be greatly appreciative.
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
Post edited by cnoat on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2010
    If your question if biamp'd does the resistance stay the same yes. Splitting them up doesn't changed the resistance of the speaker. Now I don't think rti12's are a 4 ohm speaker but a 8 ohm speaker.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • cnoat
    cnoat Posts: 315
    edited April 2010
    Thanks for your reply.They are 8 ohms.The 5400 is rated at 200 a channel running 4 and 125 running 8.So I guess I would hurt them running in a 4 ohm load?
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • cnoat
    cnoat Posts: 315
    edited April 2010
    DisneyJoe
    How do you like your halo?
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • disneyjoe7
    edited April 2010
    LOVE IT :)
    I hope you got the point.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • cnoat
    cnoat Posts: 315
    edited April 2010
    I figured.Been looking at them for a while.
    Thanks for your help
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    cnoat wrote: »
    Hello all
    How exactly are you planning on connecting that all?
    Generally, when you connect an amp to the AVR's preamp output, it bypasses the AVR's internal amp, so you likely wouldn't even be able to bi-amp them with this method. Anyone correct me if I'm wrong on that though, as I've never tried it.
    Aside from that, using two different amps for bi-amping can be complicated. Different amps have different gains, and won't necessarily match up well.
    You'd be MUCH, MUCH better off simply using the Adcom to power your RTi12's, rather than trying to bi-amp them using both the Adcom and the AVR. A good external amp is going to smoke any AVR, on any day of the week.
    I think you're still kind of confused here. The RTi12's are an 8 ohm speaker, so they'll be presenting the amp with an 8 ohm load. You won't be drawing 200 watts from the amp, but only 125. But, the Adcoms 125 watts at 8 ohms isn't going to be any different from a volume/headroom perspective, than 200 watts at 4 ohms. Due to the different resistance, either way would be the same actual power level. It's not as if you can choose to run either the amp or the speakers "at 4 ohms". The impedance of a speaker is constantly fluctuating, as the demands of the reproduced material change. An 8 ohm speaker, isn't presenting an 8 ohm load all the time. The 8 ohm rating is simply a nominal(or average) impedance rating. For instance, all of the LSi series speakers are rated at 4 ohms nominal. However, sometimes they can dip down to below 2 ohms, depending on the material they're trying to reproduce.
    As mentioned above, when bi-wiring them, each section of the speaker will still be 8 ohms.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • cnoat
    cnoat Posts: 315
    edited April 2010
    Do you think 125 a channel is enough to push them.I am running 110 right now and my rti8's sound much better.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • comfortablycurt
    edited April 2010
    cnoat wrote: »
    What AVR are you using?
    There is a WORLD of difference between an AVR's power amp section, and a good dedicated, high current external power amp. The 125 watts from that Adcom is going to completely blow away the 110 watts from your AVR. Ask anyone on this forum that's went from an AVR to an external amp...and they'll tell how big of a difference there is.
    I've run my Monitor 7A's, SDA 2A's, and the RTi8's that I used to have off of my old Onkyo 606 AVR. I thought it sounded pretty good through the AVR, but when I got my 2 channel separates...I was blown away. The 606's advertised power output is 90 wpc. The power output of my Adcom 545 is 100 wpc. A 10 watt increase isn't going to produce any kind of an audible increase in volume...however, AVR watts and real amp watts are entirely different animals.
    Once I connected my speakers to the Adcom, I found out just how big of a difference there is between the two...;
    My overall maximum volume level went WAAAY up. There's much more dynamic headroom with the Adcom, and everything has much more of a sense of musicality. In other words, you'll be just fine driving the RTi12's with 125 watts of Adcom power.;)
    Like I said above...I would strongly suggest just using the Adcom.
    Also...can you even confirm that it would be possible to bi-amp them in the method you described? Like I said above, generally when an amp is connected to an AVR's preamp output, the receivers outputs for those channels are muted, in order to reduce the load on the amp, and free up some breathing room for the other speakers.
  • cnoat
    cnoat Posts: 315
    edited April 2010
    No I really don't know if I can run my avr and an external the way I was planning.I was just assuming.Thanks for all your input.I can see you know way more than me.My 12's sound horrible.Compared to my 8's.
    Onkyo 898
    Mains rti 12
    Center csi5
    surrounds rti8
    Back Surrounds rti6
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • disneyjoe7
    edited April 2010
    Like Curt is saying above, try to run the 12's with the Adcom amp directly to see if they sound better. I think they would over an AVR, since the 12's are a bit much over what an AVR can handle.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    edited April 2010
    cnoat wrote: »
    Onkyo 898
    Mains rti 12
    Center csi5
    surrounds rti8
    Back Surrounds rti6
    With enough power those 12s should be TROUNCING your 8s!
    cnh
    tonyb Posts: 33,068
    edited April 2010
    Plus if your running all 5 channels at the same time,I'll bet your pushing less than 50 watts/per into those 12's from your receiver. Feed them some juice.
  • cnoat
    cnoat Posts: 315
    edited April 2010
    Thanks for all your input guys.I am going to pick up the adcom now.100 bucks awesome!!!!
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • comfortablycurt
    edited April 2010
    cnoat wrote: »
    For $100, that's a no brainer!! Nice find!!
    Now get that puppy hooked up!!:D
