CSI-A6 or CSI-A4
mrbrownstone
mrbrownstone Posts: 2
edited April 2010 in Speakers
First posting to the forum.....
Recently upgraded my system ......1st in about 12 yrs.......
1st time using Polk......previously had Kenwood gear(that should tell you how old the previous equipment was....I must admit...I had to warm up to the RTI 10's at 1st.......now I love them............set-up is for both home theatre & music(as I'm an avid collector/listener).....the RTI 10's were recommended by a friend,as I was originally looking for a small set-up.....but he suggested these would be better for music......
Yamaha HTR 6290 amp
Polk RTI10's(front)
Polk R150's (rear)
Polk psw111
Now I need a centre to complete....
CSI-A4 or CSI-A6.......
difference of $100 here locally to buy.....
Can't decide which to buy.....any suggestions which will compliment the system better.......as I will not be doing another upgrade for awhile.......
CSI-A6 is rather intimidating in size......is this the only difference??????
opinions......suggestions???????
Thanx in advance......:)
Post edited by mrbrownstone on
  • mrbrownstone
    edited April 2010
  • seeclear
    seeclear Posts: 1,244
    edited April 2010
    Go for the 6 if you have the space and can afford it. Not heard the 4, but much of the audio portion of movies comes through the center, and as they say, go BIG or go home. You won't regret it.
    You might want to watch Polk's ebay store ( http://stores.ebay.com/Polk-Audio-Direct ) for an A6. I don't see any on there right now, but the stock there changes regularly.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2010
    [HTML][/HTML]
    Anyone??
    CSiA6 would be a better match.
  • cnoat
    cnoat Posts: 315
    edited April 2010
    Check out the csi5,It is basically the same speaker.One call has them for 200.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • cnoat
    cnoat Posts: 315
    edited April 2010
    I had a csi3 and the upgrade to csi5 was very big.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • madnod
    madnod Posts: 79
    edited April 2010
    since the central channel is a key channel, if u can accomodate the A6 do it, it's undeniably a better center.
  • packetjones
    packetjones Posts: 1,059
    edited April 2010
    I have the A4 and am pretty happy with it. Everyone always recommends the 6 over the 4 though. It is true that if you can afford/fit the larger speaker then go with it. I could not fit the 6 in my cabinet so i had no choice but to get the 4.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2010
    Go the larger center.....very good performer.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2010
    Both will work great but the a6 is better IMO.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited April 2010
    I have the CSi-A6 and am VERY happy with it. My only problem has been finding a stand for the HD TV to sit on that the A6 will fit under. It's large compared to other centers. I did find a guy who builds really nice ones, or you can build one yourself. From what I've heard, with the RTI 10's, the 6 would match better, and worth the extra $100. My 2 pennies worth.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    edited April 2010
    +1, It's BIG, BAD AND LOUD! CSi-5 or A6..Definitely!
    cnh
    Toolfan66 Posts: 18,055
    edited April 2010
    I still want to take an RTiA9 and build a center out of it with one less driver of course..
    That would be BIG and BAD if it was done right..
    edited April 2010
    Got me there. That would be something!
    cnh
  • searay40dad
    searay40dad Posts: 82
    edited April 2010
    CSi5 has my vote too. its matched to RTis and is now the CSI-A6. check the specs. CSi5 also at Frys for $199. great sounding center.
    Thanks!
    Searay40dad
    Family Room HT/2 CH
    NAD T765hd AV Receiver
    NAD T550 CD/DVD
    NAD C270 Amp (L Ch/HF bridged)
    NAD C270 Amp (R Ch/HF bridged)
    Polk Rti12 mains
    Polk CSi5 center
    Polk PSW505 & PSW303 subs
    Polk FXi A6 surrounds
    Dish 722HD/DVR
    Samsung 50" plasma
    Sony Blu-Ray
    Weight Room (aka vintage sound rm)
    NAD 3130 Int Amp
    Denon DCD-810
    NAD 4150 Tuner
    Polk 10B monitors (still sound amazing)
    edited April 2010
    cnh wrote: »
    cnh
    The bigger question would be how you would make it FIT!!:D
  • Snowdogyyz
    Snowdogyyz Posts: 37
    edited April 2010
    I have the CSi5 and it is EXCELLENT. I recommend it highly (or the A6). I can never find an A6 on the polk ebay store, but I got a great deal on the CSi5 online.
    Denon 4311CI
    Emotiva XPA-3
    Oppo BDP-83
    Polk RTiA7 fronts
    Polk CSiA6 center
    Polk FXiA6 surrounds
    Polk PSW505 sub
    Harman Kardon HK3490
    Monitor 70
