Alpine KTP-445 Feedbacks
![Sound Waves](https://wd.vanillicon.com/db3e4d8d25ce78fb75bb77d9f76caeac_100.png)
Sound Waves
Is it a great thing to have in your car?
Has anyone uses this plug-in-play amp in their system?
Also, can it power any set of speakers especially componets efficient?
Post edited by Sound Waves on
Its not a bad little amp. Make sure you have enough room in your dash for this thing. The wiring setup will not reach under a seat. It would be better if it had RCA inputs but only high level. It can power entry level components but I would not use it on mid to high end. I guess the question is, is your system better with it or without it and I would have to say with it. It does give you more power but it acts more like a booster (old school term) than and amp.
