SVS here's what I got
rubin
Every performed a freq measurement in your room? I bet some room treatments are needed.Speakers: SDA-1C (most all the goodies)
No I haven't yet, but the room (24'x12') is pretty dead with lots of stuffy furniture.Not much standing waves.Just LOTS of bass,all I could ask for.:DEvery performed a freq measurement in your room? I bet some room treatments are needed. -
Understand but the bigger concern is dips and peaks. You may be over driving some freqs and not hearing others.
For exampleSpeakers: SDA-1C (most all the goodies)
For example
Yes You're right there are dips and peaks(in the bass) So I pick where I want to hear from eg. heavy bass or lighter bass.The 100's sound good everywhere. -
Is this a two channel rig? Looks good bro. Like those floorstanders too.Shoot the jumper.....................BALLIN.............!!!!!
yes 2 ch. -
Don't need no more!
Bass response is excellent,the biggest draw back is the excessive wall vibrations(clock wall) in particular.Don't know what I'm going to do about that,might just have to live with it.I don't think absorption material will prevent the vibration . -
Is that 3 SVS subs I see? Wow- that's awesome. You must be a bass-aholic !
Looks like one SVS and two Paradigm subs. -
2 p-dime, ps 1000,they"re no slouch but can't quite reach the depth of the SVS pc-13
