Basic speaker hookup
FRCN
I bought some speaker wire that was not color coded or marked to make sure red goes to red and black goes to black. I had a long run and lost track of which one was which. What would be the effect of the wires being mismatched at the speakers? A noticeable noise? Diluted output? I am running these wires to my surround speakers. Thanks for the help.
Steve
Steve
Out of phase...not good.
Hook them up one way, and if it doesn't sound right, hook them up the other way. You should be able to tell right from wrong. Hopefully anyway.;)
Just make sure the volume isn't real high. You'll be fine.
It's either that, or trace the run of wire all the way back.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I usually put a mark on one of them before I start so I don't get em screwed up. Also makes it easier in the future if I disconnect them. I just put some nanners on the speaker ends and will get some soon for the AVR ends. Makes life a lot easier. Welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Use a batterys' ( 9 volt or d or c ) terminals at one end and an old speaker woofer at the other. You should have another person help. Woofer goes out when Pos. is hooked up to pos terminal.Most people just listen to music and watch movies. I EXPERIENCE them.
Feel the sides of the insulation. Many wires that are not color coded have a spine(s) on one of the conductors. You can use this as your guide. E.g., spine side to negative, smooth side to positive.
There should be some type of writing on your speaker wire.Sometimes it is pretty hard to see.I use this side for my negative or black.Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
Or...instead of doing all of that...;)
You can just try hooking it up one way...and if it sounds wrong, hook it up the other way. At low volumes, this isn't going to hurt anything. I've accidentally connected speakers with the polarity reversed numerous times...and I'm yet to damage anything.The nirvana inducer-
comfortablycurt wrote: »Or...instead of doing all of that...;)
That being said, it really bugs me that there isn't any kind of standard marking system for speaker wire/zipcord. Some wires simply are NOT marked for polarity. As others have said above though, many times there is a mark that's really hard to see. Such as a notch/ridge, or very tiny writing etc. I'm guessing you've already looked for these things though.
edit-Whoops...this was supposed to be an edit to my above post.The nirvana inducer-
