lord of the ring is this a good deal
faster100
Ok i know nothing about this movie, but everyone on here refers to it, so at the local flea market a seller sells new sealed dvd's for cheap, 12 bucks and they had the 4 dvd set of lord of the ring, for 20.00 i don't know what comes with this set but is this a good deal?? and should i get it?? Let me know what all the hoopla is about this movie and also U-571 ?? they have that i think for 12.00
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by RyanC_Masimo on
LOTR - I think that's a pimp deal. Have you seen the movie???
The movie in itself is worth 20 bucks, but to give you more info on the 4 dvd set: the first two dvd's have the extended version of the film- an extra half hour not shown in the theater, bringing the total to 3 1/2 hours of pure brillance. The extended version also has DTS in addition to DD (a plus for us audiophiles). The second two discs are all extras dedicated to the making of the movie. Mainly turning the ideas and story of the book into a screenplay and props, and then casting and shooting it, discs 3 and 4 respectively.
I also have U-571, the depth charge scence is legendary for testing your systems dynamic ability. I'd pay $12 for it. -
Faster, There is a little shop off of 11th ave and 22nd st called Bananas that has the 4 disc set for $18. They have a several diffferent titles as well as thousands of used cd's. They also have vintage gear for sale. You can get the exact address from the phonebook, and since your zip is 33703, I'm guessing you are less than 4 miles away.
Thanks everyone, and thanks Flason.. i will check out that place, I have been going to funlan flea market in tampa and a seller there sells all DVD's for 12 bucks, unless its a multi disk set.. that is also where i found the seller selling AR cables for cheap... i was there this weekendMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I was watching it last night, and I would say that $20 is definitly a good deal. The one draw back to the EE version is that it is so long. I feel as though I have to plan ahead with my time before I can sit down and watch it. Therefore, I only watched it for an hour.
The sound quality is great, and I think they understand the benefits of surround sound correctly. Their use of surround was very enveloping. I felt like I was in the shire. Even with just the subtle, subtle sounds of birds chirping in the backgroud, the effects felt very professional. I would say $20 is more than fair.
