Rear Fill
Sound Waves
How many of you use rear fill in your music? Do we need it?
Post edited by Sound Waves on
Dont need it. The fewer speakers you have the better. In theory it sounds great, having some extra ambience coming from behind you but in reality it just screws up the sound.
Youre MUCH better off taking the money you wouldve spent on rear speakers and putting them towards a much higher quality set of front speakers.
I do not use it nor would I. Music is recored in 2 channel stereo and the best way to liten to it is 2 channel plus by having rear speakers your **** with your sound stage which should be in front of you.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Does this applyh to any car. I own a toyota 4runner and was wondering about using four speakers and a sub or only two and a sub.HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
Yeah, I agree with this. Rear fill is a waste.
And IMO, with my SR5250 and JL w6,
having the gains of the subwoofer set wisely, it actually sounds great in the back too!Pioneer P88RS-II | Polk Audio SR5250 | JL Audio 12w6v2 | 2x Genesis 3 Stereo 100 | Genesis 3 Monoblock -
The purpose of rear speakers is to give passengers.something to listen to. My opinion is that when my passengers start paying for my gear, then I'll start worrying about their listening enjoyment. Until then, I'll concentrate on my listening pleasure.
lmao.......:D -
haha!!
+ 12008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
That's funny!!! -
generally rear fill is a waste of ur time and $$ to setup.
but u can use it as ambient fill but only L-R attenuated would sound good. a regular L,R config would pull ur stage back... which iz bad. -
Focus up front, and it won't sound too bad 1 metre behind you either.
