Aurelex Subdude vs The FunNoodle
AudioMancer
OK, I know this is nothing new, but I found it a bit humorous.
I recently upgraded from a Velodyne MiniVee to a SPL-1200R. Man, this thing ROCKS. I couldnt get passed 45% volume without literally rattling a large picture that is in the theatre area. My wife had to take it down when we watched movies.
Ive read about the Subdude and also the home-made solutions that other members here had tried and decided I wanted to try a solution of my own. After reading about the different types of materials used, I thought Id give the FunNoodle a try. I thought, If this even half-way works, the Subdude should really alleviate my situation. So, I bought one of the larger diameter Noodles and made four 2 tall doughnuts and placed them as legs under the Velo. I checked for stability and was surprised to find the Noodle has a deceivingly strong grip. The sub did not budge.
I popped in Lord of the Rings and went to the offending scene: the Balrog chase and battle. WOW! No rattle that I could hear. Also, the bass did indeed sound smoother and tighter, as many have said; a fact of which I was admittedly skeptical. Its been four days and the sub seems to have settled in and the compression of the Noodle has stabilized.
Now, I know that as my listening skills mature, I may very well decide that I need a professionally conceived product, such as the Subdude. But for now, Im sticking with the $1.99 SubNoodle! LOL!
A/V Proc: UMC-1
AMP......: XPA-5
Speakers: Polk LCi-RTS100 x 5
Sub.......: Velodyne SPL-1200R
Bluray....: Pioneer BDP320
HD DVD..: Toshiba HD-A30
AMP......: XPA-5
Post edited by AudioMancer on
Are the FunNoodles those floaty things in the pool?
That's a great home made invention. If it works, I don't even see your need to purchase a SubDude. I got my Subdude a month or so ago and love it. BUT, if I had even thought about the FunNoodle, I would have just gotten that and saved myself $60.
Great suggestion! -
patent that puppySamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
I would have never thought of that!Sony KDL-46XBR6, Onkyo 886, Emotiva XPA-5, Oppo BDP-83, HR22 HD-DVR, Polk RTi A9s, PolK CSi A6, Polk RTi A3s, SVS PB12-NSD, Monster HTS2500 Reference PowerCenter, Logitech Harmony 1.
I've used some 3" foam furniture pads--a couple glued together under the 4 corners of a sub to decouple it from the floor. It definitely works...so I'm not surprised that pool noodles were successful as well. And they come in pretty colors.
Huck344 wrote:Are the FunNoodles those floaty things in the pool?
Yeah, that's the FunNoodle.sandworms wrote:patent that puppy
I'm thinking of buying like 10 of them, making 40 sets and selling them on EBay.
cnh wrote:I've used some 3" foam furniture pads--a couple glued together under the 4 corners of a sub to decouple it from the floor. It definitely works...so I'm not surprised that pool noodles were successful as well. And they come in pretty colors.
Nice! Didn't think of that. And, yeah, the pink SubNoodle has major WAF. LOLA/V Proc: UMC-1
AMP......: XPA-5
HD DVD..: Toshiba HD-A30 -
You even chose to name it, very cool.Shoot the jumper.....................BALLIN.............!!!!!
Too bad they don't make a gloss black noodle.
Is this the item? It looks like a great solution.
http://www.jakkspacific.com/node/744
What kind of floor does your sub sit on? Will it work well on hardwood floors on wood joists?
Jim
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
jimmydep wrote:Too bad they don't make a gloss black noodle.
You're right. My wife is into crafts and arts and she suggested I spray paint them with acrylic paint, which is slightly flexible and should withstand the minor compression as the sub settles in.
The SubNoodle has some "texture" to it so it doesn't have that "piano black" sheen, but its barely visible.Is this the item? It looks like a great solution.
Jim
Jim
Its more like this one: http://ww2.sport-thieme.de/y/450Pixel/1132205.jpg
Same one you pointed to, but different shape.
My sub sits in an entertainment nook. It's kinda hard to describe: the nook doesn't reach down to the floor, flush. It's "raised" about about 6"-8". It feels like its made of some drywall material of sorts supported by 2"x4"s. It really made the walls resonate.
I'm no expert, by any means, but I think it would work well hardwood floors. I would think that the concept of "decoupling" the sub would still apply. Maybe someone else with more knowledge can chime in on that one.A/V Proc: UMC-1
AMP......: XPA-5
