AQ Type 4
acmf74
I have a set of these speaker cables going to my mains. They have the factory terminated banana ends. Unfortunately on one of my mains the banana is loose and doesn't have a tight fitting to the speaker. Can I change the ends to spades or can I modify the banana to have a better fitting?
TIA
TIA
TIA
If you look at the banana ends do they have two small hex-screws?
If so, you can easily swap the bananas for spades - audioquest sells 'kits' of 4 that includes the small hex-wrench.
You could also just remove the banana ends and use bare wire.
There must be something wrong with that problem main of yours - I use AQ wires with banana ends and they all fit snuggly.
I would look closely at the 'bad' banana and compare it to one that fits correctly. I will bet that it is just compressed alittle and some gentle prying with an exacto or a small screwdriver would 'open' it up. Not too much is really needed.
Thanks for the replies.
I will try what kcoc recommended first. -
+1
The factory bananas can tighten up a little bit, which makes them fit more loosely.
I'm using AQ Type 4's, and the connections are very secure.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
+1 - my AQs have the same issue, sometimes they get a little loose when moved a lot. I've found a very simple fix is to take a pen and simply push it into the banana's connector to open it up enough (without opening it too much, they won't need much prying).Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600 -
i did the exact thing! helped out alot... -
My AQ4's have nanners but came with screw-on spades. If you see "male" threads at the bottom of the nanner then you should be able to do the same (the spades have "female" threads)SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
Jetmaker737 wrote: »My AQ4's have nanners but came with screw-on spades. If you see "male" threads at the bottom of the nanner then you should be able to do the same (the spades have "female" threads)
I didn't know that.
Would these screw on?
http://www.amazon.com/Audioquest-UST-spades-silver-set/dp/B000GUTS0M -
I didn't know that.
Well I googled and found a picture in a friendly place:
http://www.polkaudio.com/forums/showthread.php?t=75928
Scroll down to the third photo. Those are the spades I have.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
