anyone point me to a Ford truck forum?
danger boy
I am having fuel take system issues with my 1991 F150. I got some questions.. so I am looking for a forum where I can find out what's up with my truck.
here is the problem though if anyone has suggestions on what to do.
truck had dual gas tanks. THe front one does not work.. could be a fuel pump problem, but I think it could also be a fuse holder problem. Since the fuse holder for the tank is corroaded out. so no fuse there.
anyway, the real problem is that I can't use the front tank. i replaced the gas cap because it was building up lots of pressure and gas was gushing out every time I would remove the cap. Gushing to the tune of about a cup ever time I just loosen the cap. i siphoned out as much from the non working tank, but lots of pressure still builds up.
AND, lots of pressure also builds up in the good working tank, but it does not gush out like the other one. I never overfill the gas tank.
so i would like to solve this gas gushing problem once and for all.
bugs the hell out of me.
PolkFest 2012, who's going>?
Post edited by danger boy on
Sounds like a good project for the weekend Al, lol. Here is a Google search, the first one looks like a pretty good one. Hope you get it fixed up, IIRC you haven't had that truck long.
-Jeff
http://www.google.com/search?hl=en&source=hp&q=ford+truck+forums&aq=f&aqi=g2&aql=&oq=&gs_rfai=HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
engtaz
Those trucks with dual tanks back then were notorious for the fuel switching valve going bad. I don't remember exactly what the guys were repairing/replacing to get them to work. May want to concentrate a search into the valve.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
Also try www.blueovalforums.com.
If all else fails, I believe that a Polk member here is the owner and CEO of Ford Motor Company... -
I second what Amherst said. A buddy of mine has that same truck and had that problem and it was that valve. Now he just has to figure out why it won't stay running. You have to pulse the gas pedal in order to keep it running. It starts just fine without pumping the pedal but then you have to pumping it pretty quick after just to keep it running.
Good luck on finding out what is going on.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
nooshinjohn wrote: »
you so funnyPolkFest 2012, who's going>?
Here's another http://www.ford-trucks.com , Lot of good info.mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
i signed up with Fordforum.com I will look at other ones too though.PolkFest 2012, who's going>?
