Fritz Speakers Carbon 7
steveinaz
steveinaz Posts: 19,546
edited August 2010 in Speakers
Review: Fritz Speakers Carbon 7 Monitor
Associated equipment:
C.E.C. CD-3300 transport
Benchmark DAC1/PRE preamp
Parasound HCA-1500A power amp
Kimber Hero IC’s; Kimber 8TC v.2 speaker cable; Belden 1694A digital cable
Carbon 7 Specs:
http://www.fritzspeakers.com/Carbon%207.asp
Price as tested: $1750/pr (standard drivers/standard finish selected) 30 day return policy
The setup:
Speakers were placed 8ft apart, 12ft from the listening position, with a ½” of toe-in. They were placed on Target MR28, 28” stands. The rear corners of the speakers were 16” and 16 ½” from the wall, about 28” from the front baffle. The Carbon 7’s have a rear bass port near the top of the cabinet. Grills are provided, and very well made. They attach magnetically, and the magnets are hidden behind the wood veneer on the front baffle at each corner. All listening was done with the grills off.
The room is large, approx 14’ x 36’ and the listening area occupies the first 1/3 of the room; so there is a lot of open area behind the listening couch. Sub-floor is concrete slab, and the ceiling is vaulted.
I listened to a wide variety of music, from classical to metal and practically everything in-between. Some of the things I found noteworthy, in order of discovery:
1. Bass. Bass is impressive; tuneful and deep. They can (and do) energize my rather large listening room when notes call for it. I suspect they are hitting the 35Hz range at about -6dB level. I didn’t expect bass to be a stand-out characteristic on a monitor speaker, and I certainly didn’t expect them to be able to energize my room.
2. Ease. The Carbon 7 is laid back, easy-going and extremely delineating. It makes for a sound that you can listen to for hours on end, without fatigue. The treble is smooth, but it doesn’t cheat you out of anything—it just doesn’t let you know it’s there unduly (see integration). Music flows from these speakers with a naturalness that’s hard to describe.
3. Layering. These speakers produce a wonderful, 3-dimensional layering of sounds. You can easily hear distinct front to back spacing between performers, depending on their position in the soundstage. I have owned no other speaker that could do this to the degree these do. The soundstage is expansive, and easily escapes the confines of the cabinets, providing the source material is up to the task.
4. Integration. The woofer and tweeter sing as a single unit. It’s seamless, and makes for a very satisfying, balanced, and textured midrange. There’s no beaming, even at high output levels. Woodwind instruments sound incredibly real, having a more realistic push to the upper midrange, and less so from the tweeter. I’ve never heard cymbals sound so brassy and life-like, without calling attention to the driver itself.
5. Subtle Nuances. The warbling ring of a decaying piano note, the shimmer of a cymbal as it fades, the extension--rather than the premature end--of a given instrument or vocal. Maybe it’s the way this speaker "holds on" to detail in the decay of notes? It’s difficult to describe, but it’s there, it’s real, and it’s cool.
6. Dynamics. Output was a major concern for me, as the room is large, and I like to “get on the gas” once in awhile, especially when watching concert events where scale is an important part of the experience. It was a concern up until I allowed them to run in for a couple hours, and then preceded to punished them with an assault of hard hitting, bass heavy music. I showed no mercy. Not only could the Carbon 7 provide more than enough scale, it did so without any loss of fidelity, realism, or composure.
On the other end of the spectrum, they also sound good at very quiet listening levels. It's a great candidate for that ever special late night listening session.
Cons?:
I'm not sure if this would be considered a “con,” but these speakers lean to a warm tonal character. “Detail fanatics” may be a little disappointed in their less-than-hyper detailed presentation.
Mid bass can get a little heavy if placed too close to boundaries, I found 16” (or more) from the rear of the speaker to the wall was sufficient to keep bass response smooth and natural. This should be easily accommodated in practically any room.
I wasn't going to include this observation, because it's so minor in scope, and I'm not so confident that it isn't source related, but I felt compelled to pass it on anyway—and you can draw your own conclusions. Sometimes I get a sense that the rhythmic pace is a touch slow. It may be due to the laid-back nature of the speaker; but in the grand scheme of things, it's a minor nit pick at best.
Conclusions:
I found the Carbon 7’s to open-up after about 40-60hrs of break-in, up until that point, they’ll sound somewhat flat and recessed. Let them air-out a bit before doing any serious listening. If there were some compromises made with the design of this speaker, I’m having difficulty finding them. The Carbon 7’s ability to become a chameleon with practically any genre of music, it’s impressive bass, smooth midrange/treble, sound staging and imaging, and dynamic capabilities make it an excellent all-around performer. More importantly, it sounds elegant and completely integrated, allowing it to melt into your listening environment with ease. This is a speaker for music lovers; analytical, lab coat wearing types need not apply. Not that it lacks detail, it just doesn’t present detail in a conjured, in-your-face manner—it flows detail like a high-end purposeful design should.
The build quality, substantial heft, and gorgeously executed wood veneer is impeccable. The ease at which the Carbon 7 reproduces sound helps to tame, and lend some body to recordings with excessive treble and a flat soundstage—typical of poorly engineered CD’s. The Fritz Carbon 7 is one of the most satisfying speakers I have owned in 35 years of pursuing this hobby.
Stephen Rose
April 2010
Post edited by steveinaz on
  • dkg999
    dkg999 Posts: 5,647
    edited April 2010
    Nice review and nice looking speakers!
    DKG999
  • steveinaz
    edited April 2010
    Picture legend:
    Pic1: Left speaker on Target MR28 stand
    Pic2: Rear of the speaker
    Pic3: The room from just behind the listening couch
    Pic4: The listening couch in the foreground; showing the other 2 rooms that occupy the entire space
    Pic5: Angle pic from the front foyer
  • george daniel
    george daniel Posts: 12,096
    edited April 2010
    Very interesting--thanks for sharing.
  • curved
    curved Posts: 664
    edited April 2010
    Very nice!!
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    edited April 2010
    Nice review it makes me want to get a pair.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Excellent write up Steve. Beautiful speakers. I love your home and furnishings.
  • steveinaz
    edited April 2010
    Thanks fellas! Also, thank you Sean for giving me a lead on these.
    edited April 2010
    steveinaz wrote: »
    Cons?:
    Stephen Rose
    April 2010
    Great review! And I whole-heartedly agree with the above. I've NEVER found that to be a con....I LOVE 'warm'. That by itself could sell these for me!
    Nice pics
    cnh
  • steveinaz
    edited April 2010
    Warmth wasn't a con for me either, it was a requirement...LOL. The Carbon 7's are levels above any speaker I have owned in the last 24 years. My system as a whole sounds much more impressive, as represented by these speakers. I'm glad I made no changes upstream.
  • Face
    Face Posts: 14,340
    edited April 2010
    Very nice Steve.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2010
    Great write up Steve, move from your Energy, I can see how these would be on the warm, laid back side of things. I think you are probably getting a more accurate representation of the top end compared to what you have been listening to.
    Are there any users out there using these with tube amplifiers? I just wonder if they would be too laid back, especially if you feel they are already on the Parasound / Benchmark combo.
    Cheers,
    Russ
  • steveinaz
    edited April 2010
    I haven't had soft dome tweeters in many years, I'm really enjoying the smoothness they provide.
    Russ, I may not be using the term laid back correctly---what I mean to say is that the treble is in no way "in your face." They seem only slightly less efficient than my C-9's, requiring just a little more volume knob; even when I was rocking them, I never went past 12 o'clock on the Benchmark.
    Wes will be bringing his Cary amp down when we have the get together this summer.
  • polkatese
    polkatese Posts: 6,767
    edited April 2010
    Very nice review Stevie. Also, you have an excellent decor and taste. Make me feel like to hang out in your living room. :)
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • steveinaz
    edited April 2010
    Thanks man, my wife says I'm the gayest straight man she knows. She likes the way I decorate, so she wanted me to do it. Eventually the carpet in the livingroom with probably be replaced with hard wood flooring--but we're still thinking that one through...
  • BottomFeeder
    BottomFeeder Posts: 1,684
    edited April 2010
    Love the corner treatment - whatever that thing is.
    Great write up.
    "Wish I didn't know now what I didn't know then." Bob Seger
  • steveinaz
    edited April 2010
    It's one of those sante fe indian ladder thingies.
  • steveinaz
    edited April 2010
    Just a follow-up;
    I have probably another 60 or more hours on the Carbon 7's, and they continue to impress. I was listening to Bruce Hornsby the other day, and fell into sonic bliss. Their midrange and upper bass reminds me of early AR monitors such as the AR58 or AR98Lsi. They have a sealed enclosure sort of sound to them. Just a point blank joy to listen to. They have a unique talent for making practically everything sound better. I did the "ugly baby" test the other day, using discs that are down right awful; the 7's did a good job of making them more listenable. Lake's first album (On the run; Time bomb, etc), Nazareth (Hair of the dog--I was using this disc as a beer coaster, so I though it would be a good candidate), and SIN of Audio Sins, the horribly recorded Kansas (Point of Know Return) all sounded much better---still lacking seriously, but better.
    I wailed on them yesterday with some Black Sabbath, "Heaven & Hell" ala Ronnie James Dio-- the disc has never sounded better, in fact I'm sure I had a woody during "Lady Evil."
  • hearingimpared
    edited April 2010
    Glad your digging them Steve.
  • pearsall001
    pearsall001 Posts: 5,373
    edited April 2010
    Great review, great speakers & a beautiful room! Nothing like listening to a superb pair of monitors. I'll bet you don't miss the old floorstanders at all. Sit back, relax & enjoy!!!
  • steveinaz
    edited August 2010
    BTT for Wes/Bill.
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2010
    Sorry it took a few days to get to this.
    Anyway, these are some fine monitors. I echo everything Steve has said. I just want to emphasize that the bass on these things is impressive all-around: quantity, detail, realness. They are certainly non-fatiguing to listen to. Female vocals sound nice too. While I hadn't listened to them very much on the Parasound, I would say that as long as you have at least that level of gear, the Carbon7's should deliver very nice results.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
