Klipsch Promedia V2-400 4.1 system
Anyone own or have owned these.I have had mine for 8 years or so and this is probably one of the best systems for gaming. But as has happened to so many others I now have an output failure.:(
The rear right channel no longer works----at all.
Has anyone here ever repaired these or sent them out to be fixed??There is a seller on ebay who can fix them and add a fan inside the sub to keep the overheating parts cool which caused the failure in the first place to so many of these fine gaming speaker systems.
Just wondering if I should have it fixed and upgraded.The cost doesnt seem to high at around 120.00.The kit is 29.95 but that may not include the parts needed to fix the output that no longer works.
Link to more info. http://cgi.ebay.com/KLIPSCH-ProMedia-5-1-THX-Computer-Theater-Speakers-Sub_W0QQitemZ330418026659QQcmdZViewItemQQptZPCA_Speakers?hash=item4cee72f8a3
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
