lowered price to only $ 28,000
AudioGenics
AudioGenics Posts: 2,567
edited April 2010 in The Clubhouse
TRITIUM AIR BEARING BRASS PHONO TURNTABLE RECORD PLAYER - $28000 (Milwaukee Wi)
Date: 2010-03-09, 3:10PM EST
Reply to: sale-p9wet-1636241085@craigslist.org [Errors when replying to ads?]
SEE IT IN OPERATION ON YOUTUBE, SEARCH FOR "TRITIUM AIR BEARING"
TRITIUM AIR BEARING TONEARM COPYRIGHT (C) (P) 1998/2010
ULTIMATE TURNTABLE / TONEARM DESIGN
TRITIUM WORLD CLASS STATE OF THE ART TURNTABLE & AIR BEARING TONE ARM
Superbly designed turntable for a lifetime of musical pleasure The culmination of 30 years of research and development.
Viscous damped in the vertical and horizontal plane.
Damping takes place at the head shell for maximum control.
Undamped tonearms have a colored presentation from vibrations set up in the headshell and Vinyl LP by the needle.
Their sound is far from what is possible from the Vinyl LP format.
Undamped tonearms are the "also ran" or "not even in the ball park" in terms of fidelity, tracking and Vinyl wear.
Tritium's Tonearm is a perfect design for Medium to High compliance cartridges and gives a 10 to 12 hertz tonearm resonance frequency.
Low compliance cartridges are typically heavier to compensate for the stiff cantilever suspension.
Light weight Low compliance cartridges can be easily optimized on the Tritium arm with additional tonearm mass.
Tonearm weighs about 34 Grams with this 8 gram cartridge and has a 10 hertz tonearm resonance frequency.
( VTA ) Vertical Tracking Alignment adjustment is an Allen screw on top of the Tonearm pivot.
This alters VTA + or - 1 degree per 1/2 rotation.
Air fitting mounted on the side is the "Air manifold input"
TRITIUM'S Perfectly Balanced Tonearm's Tracking Capability can play any album ever cut.
A Sumiko Bluepoint cartridge with over 4,000 playing hours on it!
And no visible wear under a 700 power Stereo microscope
AMAZING... !
Lowest Mass, Lowest Wear, Highest trackability Highest compliance tonearm in the world.
-COMPLETELY FRICTIONLESS for the MOST ACCURATE LP PLAYBACK EVER-
NO pivoted or linear arm design available can compare!
33 RPM, 45 RPM and Optional 78 RPM
Tritium Air Bearing Turntable
OWN THE ULTIMATE TURNTABLE! The culmination of 30 years of research and development results in this superbly designed turntable for a lifetime of musical pleasure! Comprised of the ultimate precision machining unmatched in performance.
TONE ARM ASSEMBLY:
- The lightest, strongest, least resonant and most accurate tracking pickup arm ever made.
- Tone arm moves effortlessly in horizontal and vertical directions with compressed air and is damped by viscous fluid.
- It is COMPLETELY FRICTIONLESS!
PLATTER ASSEMBLY:
- Precision designed to damp out disruptive energy!
- Platter has a layer each of Aluminum and Brass with a Copper top platter mat.
- 2 separate layers of ISO-DAMP for perfect playback!
- Suspended on a Brass/Bronze ball bearing and nylon thrust pad for smooth operation.
- Rotor is designed with a .017" slope to remove record warps and virtually eliminate all subsonic wow.
PLINTH (BASE) ASSEMBLY:
- 2-piece base comprised of 70 lb 1.2" Aluminium plates.
- Layer of ISO-DAMP compound between the layers to dampen and absorb incoming and outgoing vibrations to very low levels.
- Plinth rests on 4 adjustable brass leveling legs.
MOTOR:
- Pulley is precision machined for accurate 33 or 45 RPM playback.
- The High Torque Aluminum motor with a brass base.
- Includes 4 adjustable feet.
- Alinco 48 pole, 115 VAC, .6 amps, 600 rpm, 1/150 HP.
AIR PUMP:
- Air Pump is a Medo linear piston pump.
- Unit is very quiet and can be placed up to 100 feet from the listening area.
- Includes 100 feet of air tubing and a surge tank with a 2 gallon capacity.
Included:
- Polished Brass and Copper Record Weight with a nylon insert for quiet spindle touchdown.
- Phono Output Connector Box is a machined aluminum billet with gold RCA connectors and a ground connector.
- Power Switch is a heavy threaded aluminum cylinder.
- Heavy duty power cable.
- High torque belt drive.
- Tritium logo is attached to the plinth.
Turntable is a great addition to any analog enthusiast's collection! The precision machining and unique design ensure amazing playback unmatched by any other turntable design! Makes a great gift and will provide years of listening pleasure.
This is a UNIQUE design hand crafted by the experts at Tritium.
** For more pictures of the table, feel free to email and ask.
EVERYTHING IS INCLUDED. TURNKEY ULTIMATE ANALOG EXPERIENCE.
TRITIUM TURNTABLE w/ AIR BEARING TONEARM 48 POLE MOTOR COPYRIGHT (C) (P) 1998/2009
TUBE HIFI, GUITAR, SOLID STATE HIGH POWER PA AMPLIFIERS REPAIRED.
TUBE AMPLIFIER PREAMP PARTS AND REPAIR, SURROUND AMPLIFIER REPAIR.
HIGH END TURNTABLES, PLATINUM CABLES, HIFI UPGRADE AND MODS.
ELECTROSTATIC SPEAKER PARTS, TRIPHAZER POWER CONDITIONERS.
TURNTABLE, TONEARM REPAIR, BELT AND NEEDLE REPLACEMENTS
MUSIC PRODUCTION, CD REMASTERING,VIDEO EDITING.
VISIT US AT TRIPHAZER*COM, TRITIUM ELECTRONICS 414-475-0007
FREE ESTIMATES, PUBLIC ADDRESS
8301A W LAPHAM ST. WEST ALLIS WI 53214
it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1636241085
Post edited by AudioGenics on
