ADCOM question
sda2mike
sda2mike Posts: 3,131
edited April 2010 in 2 Channel Audio
i have a gda 600 DAC..i just received a gcd 600 CD player...would it be superflous to use this DAC with this CD player? i don't know anything about the components being used internally..i thought i'd post this question before i get into the acrobatics of getting to the back of my rack:)
thanks
mike
  • concealer404
    concealer404 Posts: 7,440
    edited April 2010
    I thought one of the features of the GCD600 was that it had the GDA-600 built in. But i could be making that up, i guess.
    Me? I'd give it a shot. If it sounds better, use the DAC. If it doesn't, ditch it. If it sounds exactly the same, ditch it. :)
  • sda2mike
    edited April 2010
    thanks...i was hoping to get a solid opinion before i tear into the rack/wires/mess...yours, will probably be the best advice me thinks:rolleyes:
    heiney9 Posts: 25,721
    edited April 2010
    No, the gda600 is even better and follow this thread to make it World Class.
    http://www.polkaudio.com/forums/showthread.php?t=97185
    Concealer404, you're thinking of the GCD750 having basically the same DAC section as the GDA700. Not the same between the two the OP has.
  • concealer404
    edited April 2010
    heiney9 wrote: »
    Dammit. You're right. Thanks for the correction. :)
