Power Conditioner Question ???
dee1949
dee1949 Posts: 1,425
edited March 2010 in The Clubhouse
...Best Solution
...Can you plug an ac plugin strip into a line conditioner. Most connections wouldn't be on at the same time. I take it the ac conditioner should be plugged into a wall outlet??? or can it be in an ac outlet strip??
Post edited by dee1949 on
  • potee
    potee Posts: 610
    edited March 2010
    I don't think thats a good idea as you would have alot of power using one source. It might start blowing fuzes or tripping breakers, depending what else you have on the outlet strip.
    Paul
  • AudioGenics
    AudioGenics Posts: 2,567
    edited March 2010
    what are the electrical specifications of the line conditioner and the power strip.
    check the ratings.
    Ohm's law prevails
  • thsmith
    thsmith Posts: 6,082
    edited March 2010
    Dee, I just scanned my APC H15 manual and found no restrictions but I know you should never plug the main unit (H15) into a power strip.
    If you plan to run a small powerstrip with a few low voltage devices that will not be on when the main units are on would be ok, I guess.
    I am doing something silimliar but I am using a 12v trigger to turn on my WD TV when that source is selected on the AVR. the trigger is a single outlet device which is all I need in this case.
    Hope that helps.
