Slight noise from lsi speakers
@@@@@ Posts: 115
edited April 2010 in Speakers
I have 9.2 set up. My speakers are all lsi series and I have xpa 2 fro my L/R ( lsi 25 ) and xpa 5 for my C ( lsi C )and surrounds A/B ( lsi 9 -- 4 pieces ) and upa 2 for my (lsi/fx) surrounds back. I guess I have excellent set up. But there is something bothering me about which is the buzzing coming from each speaker specially surrounds A/B ( lsi 9 ) powered by xpa 5. I aleready tried everything including electrical power distribution and I still hear noise from speakers. I can hear this noise if my ear touches the coil of the drivers and not from any of my listening positions.
Can anyone tell me if this noise is normal? It looks like it is an electrical sound. Also, noise is only heard if the system is on. Furthermore, I already tried connecting my apms directly to the electrical outlet on the wall and connecting them to power surge and yet this noise still persists.
Please advise me what to do.
Thanks,
Post edited by @@@@@ on
  • over50
    over50 Posts: 201
    edited March 2010
    Not sure if you problem is same problem i had., but i had a hum coming from my sub. i bought a ground loop isolator and now its gone. somehow the circut is broken when a isolator is installed and breaks the circut.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
    @@@@@ Posts: 115
    edited March 2010
    What is a ground loop isolator and where can I but tht staff?
    @@@@@ Posts: 115
    edited March 2010
    over50 wrote: »
    Can you please tell me where i can find that ground loop isolator?
  • george daniel
    george daniel Posts: 12,096
    edited March 2010
    Radio shack,,etc this is the one I use,, costs a little more--very good IMHO,,here you go,,
    http://www.markertek.com/Video-Equipment/Video-Processors/Video-Noise-Hum-Elimination/Jensen-Transformers/VRD-1FF.xhtml
  • over50
    over50 Posts: 201
    edited March 2010
    Radio Shack only had isolators for cars.i bought mine on amazon . i needed a hook up for cable. I attached the isolator to my cable box, works fine. just google ground loop isolator and you will get lots of info.the viewsonic i bought was $25.00 very affordable.I also just bought a channel master amplifier.its attached to the cable line comming in, its splits the signal and boost. its a digital distribution amplifier. Channel Master's CM 3418 .
    http://www.amazon.com/Viewsonics-VSIS-EU-Isolator-SATELLITE-SYSTEMS/dp/B0017I3K9M/ref=sr_1_3?ie=UTF8&s=electronics&qid=1269861528&sr=8-3-spell
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
    @@@@@ Posts: 115
    edited March 2010
    But in my case, I have 9.2 set up. will that mean that I need to buy 9 isolators to stop the buzz/hum on my speakers? I am only asking, my new friends. And what kind of isolators do i need to buy?
    edited March 2010
    I think what the guys are trying to tell you is that the most common cause of a ground loop is your cable line to the TV. In that case all you need is ONE ground L. Isolator because that is what is passing into your AVR/amps and from there to the speakers.
    If that is your problem this should solve it. If that's not it. It won't.
    cnh
  • over50
    over50 Posts: 201
    edited March 2010
    That`s a hard question to answer. If you do have a ground loop problem ,then you have to figure out with which equipment. Thats the hard part. I disconnected the cable and the hum went away, i new that was my problem and connected the isolator to the caBLE GOING into the cABLE BOX.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • over50
    over50 Posts: 201
    edited March 2010
    cnh, good job explaining common cause.Thanks.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
    @@@@@ Posts: 115
    edited March 2010
    If the cable box is the one causing this problem, how come that whenever my speaker cables are directly connected to my avr 5308, there is no any noise coming from any of my 9 speakers? Also, I tried to disconnect the my satellite wire from the power surge and disconnecting also the cable from the back of my cable box, the problem still persists.
    Please tell me more about how to resolve this irritating noise from my speakers before my mind gets damaged.
    edited March 2010
    Hmmm that does sound like it might be one of your Emotiva amps. You did say that you tried connecting all of them to the wall sockets directly, no? If I'm not mistaken that is what Emotiva recommends?
    You will have to isolate which component it is in the same way. There are some other devices that help with ground loop problems...I'll check my files...
    cnh
    @@@@@ Posts: 115
    edited March 2010
    Adding to this story: I have two sets of home theaters in my house. the first HT is composed of lsi series powered by emotiva products, my amps ( 9.2 set up) with avr 5308 as my pre amp and the second HT is composed of monster thx series powered by onkyo 906 without amps.
    The issue is that I don't have noise from my second HT, but I have noise from my first HT.
    So please advise me what to do and I will follow it before it will destroy my mind.
    Thanks!!!
    @@@@@ Posts: 115
    edited March 2010
    cnh wrote: »
    cnh
    Thank you so much for your help, guys, in advance!!!
    Yes, I already disconnected everything from the electrical power keeping only my xpa 5/2 and upa 2 plugged in to the power supply and yet the problems still persists.
    edited March 2010
    There are a number of equipment GLEs....one is the ebtech Hum-X which allows you to plug it between the device and the wall socket. I've never used these devices since my problems have usually been cable related. But you might want to try one...or something similar?
    cnh
    edited March 2010
    @@@@@ wrote: »
    What I was suggesting is that you REMOVE all Emotivas from any power surge supply and plug them directly into wall sockets and see if that does anything.
    Or is that what you are saying...Supposedly, Emotivas have their own current surge protection? I suspect the amps are interfering with each other.
    BTW....you have some nice pieces there. Two flagships: a Denon and the Onkyo.
    cnh
    @@@@@ Posts: 115
    edited March 2010
    cnh wrote: »
    cnh
    I'll try that just to eliminate noise once and for all. Thanks a lot!!!
    @@@@@ Posts: 115
    edited March 2010
    cnh wrote: »
    What I was suggesting is that you REMOVE all Emotivas from any power supply and plug them directly into wall sockets and see if that does anything.
    cnh
    They have beed plugged in directlly to the wall and yet the noise continues to irritate my ear.
  • Agent
    Agent Posts: 65
    edited March 2010
    I have you tried swapping out your interconnects? Probably not it though since you are hearing it from every channel. Can't be your avr if you don't hear the noise when speakers are ran directly through it. Try using a different surge protector. If some things are still plugged into it, it may be still interfering. Definitely don't plug your Emotiva amps into the surge protector. They have their own built surge protection. Did you try the ground loop isolator yet? Other than that, call Emotiva and have a chat with them. Maybe they can suggest some things or maybe they will conclude that one of your amps have an issue. Have you tried hooking up those amps to your other HT system? If the problem persists then you know what the problem is.
    Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 = :D
  • PSOVLSK
    PSOVLSK Posts: 5,371
    edited March 2010
    Agent wrote: »
    I have the same issue with my XPA-5 and this really helped my problem. What I have decided the issue is with mine is that there is a slight hum in the amp that is in turn sent to the speakers. Before I changed out my IC's and made sure they weren't near any power cords, it was audible while sitting down and even during quiet movie scenes. Now I have to actually put my ear to my speaker to hear it so it doesn't bother me.
    @@@@@ Posts: 115
    edited March 2010
    Agent wrote: »
    I have you tried swapping out your interconnects? Probably not it though since you are hearing it from every channel. Can't be your avr if you don't hear the noise when speakers are ran directly through it. Try using a different surge protector. If some things are still plugged into it, it may be still interfering. Definitely don't plug your Emotiva amps into the surge protector. They have their own built surge protection. Did you try the ground loop isolator yet? Other than that, call Emotiva and have a chat with them. Maybe they can suggest some things or maybe they will conclude that one of your amps have an issue. Have you tried hooking up those amps to your other HT system? If the problem persists then you know what the problem is.[/QI
    I already tried everything suggested to me, and I already called emotiva and I was told that there is nothing that they can do since the noise is only heard whenever my ear is less than 1 ins away from the speakers.
    Lucklly I found the cause of the noise. The said noise from the speakers is only generated if the interconnects are connected to avr but if it is removed, the buzz/hum is gone. The question now is how will I listen to the music if the interconnects are disengaged from the reciever? or Do I need to use different interconnects? Where can I buy these different interconnects?
    @@@@@ Posts: 115
    edited March 2010
    PSOVLSK wrote: »
    That's also my findings. I removed the interconnects and the noise disappeared. I think I have to buy different interconnects to see if the problem will continue to persist. By the way, What local electronic store can I buy interconnects?
  • PSOVLSK
    edited March 2010
    Buying a couple of the ground loop isolators and running them between the AVR and amp might work. You could always return them if it didn't work. Many places to get IC's, but get some that are well shielded. www.signalcable.com is a good choice. Also check auidiogon.com for some used cables. You can often get a good deal from someone who is upgrading.
    @@@@@ Posts: 115
    edited March 2010
    PSOVLSK wrote: »
    Can you please specify the kind of ground loop isolator I should buy and its local store so that I can buy them now?
  • PSOVLSK
    edited March 2010
    Although it's made for autos, I've used the $16.99 one with success in my home. As I said, if it doesn't work you can always return it.
    http://www.radioshack.com/search/index.jsp?kw=ground%20loop&origkw=ground%20loop
    @@@@@ Posts: 115
    edited March 2010
    PSOVLSK wrote: »
    Do you thin I can put it in between my emotive and avr?
  • Agent
    Agent Posts: 65
    edited March 2010
    I'd try these.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
    You can't beat the price and if it solves your problem then you have found yourself a rather inexpensive fix. If it solves your problem and your one of those guys that have to have uber expensive cables then at least you can upgrade without wasting X amount of dollars if it wasn't the problem in the first place. By the way, I use these cables and think they are excellent. I initially bought sidewinders but bought these for comparisons sake and to be very honest, they sound every bit as good as the sidewinders, so I just returned the sidewinders.
    @@@@@ Posts: 115
    edited March 2010
    Agent wrote: »
    I'd try these.
    Thank you my friend! I will buy this to see if it will permanently end the annoying noise from the speakers.
    I will let you know the result soon.
    If there is still any suggestion, please share it with me and I'll do it just to remove this noise that sounds like buzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz!!!!
  • PSOVLSK
    edited March 2010
    Agent wrote: »
    I'd try these.
    Those look like a good choice. I have some IC's from monoprice that I don't really like, but these look to be higher quality than the ones I own.
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2010
    Not all amps are dead silent, so it might just be the amp, the sensitivity of the speakers, and your sensitivity to the buzz. Hopefully it's something concrete that you can solve, but maybe it isn't. For your ear to have to be basically touching the driver to hear it, it kind of sounds to me as if this is a non-issue.
    Edit: And not all preamps and sources are dead quiet either, for that matter.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    @@@@@ Posts: 115
    edited March 2010
    tcrossma wrote: »
    You may be right. However, the channel 1/5 of xpa 5 is producing noise 2 inches from the coil and channel 2/4 at least 1 nch away from the speakers. Than's my real problem. Do you think changing the interconnects will solve the issue?
