mm120 box help
Systems
i purchased a mm120 sub at a really good price a while back and im looking to get a box since i dont have the time to make my own. the one i am looking at is here: http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1290265098. will this make the sub sound alright? im no expert at dimensions and whatnot for a sub which is why i came here. if that box doesnt work, is there one you could recommend?
thanks
thanks
Testing
Testing
Testing
Testing
Testing
It doesn't look like that box will work. The ports look way too short. If you want a bandpass box, we have a very specific recommendation. The easiest route would be to get a sealed box of about .88 cu. ft., and you should easily be able to find one for cheap. Lots of shops carry pre- fab MDF enclosures that are at or near this volume. The bandpass box will be louder, but don't just throw the woofer in any bandpass because it won't sound good.Testing
Testing
Testing
