Mix Series?
Hello I am currently in the process of putting together a home theater system. I have the Polk M20s (floor), PSW10 (sub), CSR (center), and I was planning on getting the M10s (bookshelf) to go with the M20s. But I am able to get the R150s for $100 less. Is there a difference between the two that I will hear? Will the M10s give me better sound since its in the same series? Or can I go ahead and mix them. Help would be much appreciated, Thanks!
Post edited by Plastiq on
If these are going to be surround speakers then it is not as important to have them match. In my opinion I would save the $100 and get the cheaper ones.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Okay, thanks for the reply. I am also going to be using the system a bunch for music though (not just surround for movies).. is it still okay to mix or is it better to keep them matched?
